gas nozzle in vacuum chamber
Old   January 22, 2016, 08:53
Default gas nozzle in vacuum chamber
PaoloP
paolo.pizzol is on a distinguished road
Hi all!
To start off, I'm very new to Openfoam.
My problem: I am trying to simulate a gas (Argon) entering a vacuum chamber (pressure in the mbar range, 1 - 10 mbar) at a certain speed (or mass flow, whichever).
I'm starting with simple geometries (pipe, nozzle on one side, outlet on the opposite side) but so far I've had no luck.
Which solver should I use? Boundary conditions?
Any help is of course appreciated!
Thanks!
Paolo
paolo.pizzol is offline   Reply With Quote
Old   January 22, 2016, 11:01
chirag khalde
chirag is on a distinguished road
Hi Paolo,
I am also working with similar problem. I could simulate flow in vacuum chamber but I still have some problems.
I have used rhoCentralFoam and pisoCentralFoam.
My simulation used to diverge as numerically pressure used to go below 0 pa. So i limited it to 0.000001 pa in the solver.
In both the cases, I have observed is that I get a strage velocity profile near the shock region. I performed a fluent simulation on same geometry but this problem is not observed.
May be someone can help out.
link for my thread with the files attached in it!
http://www.cfd-online.com/Forums/ope...ntralfoam.html
Thanks!
Chirag
chirag is offline   Reply With Quote
Old   January 22, 2016, 11:06
PaoloP
Thanks Chirag! I'll try the solvers and see how it goes :-)
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Vacuum chamber gustavosimiema FLUENT 0 June 9, 2015 09:10
error message cuteapathy CFX 14 March 20, 2012 06:45
how to simulate velocity field of supersonic gas (400m/s) from a nozzle to a chamber CYMa OpenFOAM 3 December 15, 2009 21:31
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
