March 4, 2016, 07:45 |
extrude2DMesh
Rep Power: 14 |
Hello everybody,
i wrote a little program which automatically produces a 2D mesh around any given airfoil. I exported the mesh data into the files points, faces, cells and boundary. When i want to extrude the mesh with extrude2DMesh i get following output: Code:
Extruding from polyMesh2D at time 0 Selecting extrudeModel linearDirection Adding patch front at index 3 for front faces. Adding patch back at index 4 for back faces. ****Problem with boundary patch 0 named inlet of type patch. The patch should start on face no 0 and the patch specifies 136. Possibly consecutive patches have this same problem. Suppressing future warnings. Added 57 points to layer 0 Added 57 points to layer 1 Uncollapsed edges = 0 / 229 Number of points : 114 Not visited : 0 Not collapsed : 114 Collapsed : 0 Collapsing 0 cells Writing extruded mesh to time = 1 End I attached the 2D Mesh wich my program exported. For testing purposes it is a really coarse mesh. Dou you know what i'm doing wrong? thank you Chris |
March 24, 2016, 14:48 |
Rep Power: 10 |
hi ChrisPro
I have this problem too. Did you solve it. best regards masoud |
[Other] extrude2DMesh does not work ! | ooo | OpenFOAM Meshing & Mesh Conversion | 3 | July 5, 2013 11:19 |
[Other] Extrude2dmesh | neri.alamanni | OpenFOAM Meshing & Mesh Conversion | 8 | October 11, 2010 11:22 |
[mesh manipulation] extrude2Mesh stucks on error "created illegal face" | draufunddran | OpenFOAM Meshing & Mesh Conversion | 0 | September 20, 2010 04:32 |
