extrude2DMesh
Old   March 4, 2016, 07:45
Default extrude2DMesh
ChrisPro is on a distinguished road
Hello everybody,
i wrote a little program which automatically produces a 2D mesh around any given airfoil. I exported the mesh data into the files points, faces, cells and boundary.
When i want to extrude the mesh with extrude2DMesh i get following output:
Extruding from polyMesh2D at time 0
Selecting extrudeModel linearDirection
Adding patch front at index 3 for front faces.
Adding patch back at index 4 for back faces.
 ****Problem with boundary patch 0 named inlet of type patch. The patch should start on face no 0 and the patch specifies 136.
Possibly consecutive patches have this same problem. Suppressing future warnings.
Added 57 points to layer 0
Added 57 points to layer 1
            Uncollapsed edges = 0 / 229
    Number of points : 114
    Not visited      : 0
    Not collapsed    : 114
    Collapsed        : 0
Collapsing 0 cells
Writing extruded mesh to time = 1
End
The mesh is created and can be viewed in paraView. Anyway simpleFoam is not able to execute the solution.
I attached the 2D Mesh wich my program exported.
For testing purposes it is a really coarse mesh.
Dou you know what i'm doing wrong?
thank you
Chris
ChrisPro is offline   Reply With Quote
Old   March 24, 2016, 14:48
masoudsh is on a distinguished road
hi ChrisPro
I have this problem too.
Did you solve it.
best regards
masoud
masoudsh is offline   Reply With Quote
[Other] extrude2DMesh does not work ! ooo OpenFOAM Meshing & Mesh Conversion 3 July 5, 2013 11:19
[Other] Extrude2dmesh neri.alamanni OpenFOAM Meshing & Mesh Conversion 8 October 11, 2010 11:22
[mesh manipulation] extrude2Mesh stucks on error "created illegal face" draufunddran OpenFOAM Meshing & Mesh Conversion 0 September 20, 2010 04:32
