checkMesh fails after introduction of a cyclicAMI
Old   November 9, 2017, 05:51
Default checkMesh fails after introduction of a cyclicAMI
elomri is on a distinguished road
Hello everyone,
I'm relatively new to OpenFoam and new to this Forum which means that i still has a lot to learn from you all, so thank you in advance !
For my case i'm using OpenFoam 4.1. I first load a fluent mesh which is rather a complex one with several interfaces and bodies (the same mesh works perfectly in CFX).
I use fluent3DMeshtoFoam to convert the mesh and it goes well and the boundary file is created with all the patches and walls i already had previously in CFX.
At this point, running the checkMesh was no problem at all and the log out of it is (first_checkMesh).
When i try to modify the boundary file to change the types of some patches to cyclicAMI i get the error attached as (second_checkMesh). Same error if i launch rhoSimpleFoam.
May be important to mention that originally all the boundries in the file boundary are only patch or wall.
I looked into some threads and the error seems to occur because the the number of patches in boundary does not match with the declared number of patches which i checked and is not the case.
I also attach my modified boundary file.
Your help is much appreciated !
elomri is offline   Reply With Quote
Old   November 9, 2017, 06:55
M. C.
student666 is on a distinguished road
The errors you face are dummy errors...you deleted some }) in some definition of patches...
In any case with first output, if I were you, i should consider to remesh, especially for the 22614(!!!) faces with higher non-orthogonality (>80). Further more even with few skewfaces and high aspect ratio cell, you can have problems...
Regards
student666 is offline   Reply With Quote
Old   November 9, 2017, 09:11
Thanks for the reply.
I'am aware of the non-orthogonality problems im my mesh which will be one of the next steps to deal with.
I'm sorry but i still don't see where i missed the some of } or ). could someone point that out ?
Thank you in advance
Old   November 9, 2017, 15:21
M. C.
indeed the error message could lead to misunderstanding, but reading carefully, it tell us that an
or EOF
is missing.
e.g.
        neighbourPatch  OUTLET_SPIRALE_TO_OUTLET_BOX-SIDE-2;
Regards...
Old   November 10, 2017, 02:19
Thank you very much, it was indeed a dummy error.
regards
GGI and Topological changes - checkMesh fails strakakl OpenFOAM Programming & Development 4 November 10, 2019 05:48
Reconstructing cyclicAMI fails Perfectdark OpenFOAM Running, Solving & CFD 1 April 29, 2016 03:49
plateHole in solidMechanics/elasticSolidFoam fails checkMesh in Opt but runs in Debug ripudaman OpenFOAM Bugs 3 December 1, 2015 18:08
[Other] CheckMesh fails when cyclic boundaries are defined - OF 2.2.0 caduqued OpenFOAM Meshing & Mesh Conversion 2 May 21, 2013 18:31
Compiling checkMesh fails kjetil OpenFOAM Installation 1 February 8, 2010 11:05
