Output patch at arbitrary position in domain
Old   January 30, 2018, 09:28
Default Output patch at arbitrary position in domain
Oskar
oskar is on a distinguished road
This can probably be done in post-processing also. But I think creating the patch in pre-processing should reduce the work-steps needed to get values out afterwards.
So I basically have a domain with internal and external flow. I'm trying to get a patch placed in the internal flow section, to be able to get the massflow through the internal section. I want to run several of these with varying geometry, and plot trendlines in relation to the geometry.
At the moment I'm outputting a CAD geometry from solidworks with a .stl file. Then snappyHexMesh:ing to get the domain in one go. (outer bounds is just a simple square)
But I've never seen this type of data extraction used before.
Is there any way to create a patch at a arbitrary place, and have snappyHexMesh fit the mesh to the patch?
oskar is offline   Reply With Quote
Old   January 31, 2018, 06:02
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Yes, you can make them faceZones. I would suggest some searching for "snappyHexMesh faceZones" to give some ideas.
Regards,
Tom
tomf is offline   Reply With Quote
Old   January 31, 2018, 11:43
Oskar
Thanks for pointing me in the right direction Tom!
I found some threads about using faceZones from setSet and topoSet. And they seem to be exactly what I need.
However, I haven't been able to find any good basic example of how to actually do this. You wouldn't happen to have a link or a short simple description handy?
Old   February 1, 2018, 05:54
Tom Fahner
The excellent collection of tutorials of Tobi comes to mind. His setset part on the website may be of help?
I did not check it myself, but from the description it looks like it will cover many topics, amongst which probably yours.
Regards,
Tom
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 10:38
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
