October 4, 2019, 07:06 |
Export/Initialize Profile Data as a BC
Borjan Petreski
I've been searching the internet for a specific inlet BC but I couldn't find anything for now (maybe it exists but I simply cant find it). First of all I will try to explain what I plan to achieve. I have a radial fan case which has an outlet patch with resulting Ux, Uy, Uz and Umag of course. I would like to export these values in .csv format but also include the direction of the vector because basically when you have a radial fan the vectors are in the direction of rotation. When I run my case (a chamber supplied by 4 radial fans simultaneously) I would like to Initialize the Profile Data (velocity vectors with direction and magnitude) exported from the radial fan case as an inlet patch BC. That way I can correctly simulate the airflow velocity and direction inside the chamber and the turbulence caused by the mixing of the four radial fans. Is this possible in OpenFOAM? 1. Exporting outlet patch Profile Data in .csv format. 2. Initializing Profile Data as a BC in another case at the inlet patch. (the outlet of the first case and inlet of the second case is the same surface) |
export profile data, initialize profile data, profile data, profile data bc |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
CFXSolver Error Message using Profile Data on B | Tobias | CFX | 0 | August 26, 2005 07:27 |
