May 22, 2020, 19:46 |
Unable to generate OBJ file for OpenFOAM
anonymous
I am trying to generate an obj file from a 3D model that I created in Inventor 2016. However, the OBJ file format is not available in this program when I tried to export my model. Does OpenFOAM support another type of CAD forrmat that I could use, like STEP or JT file format? |
May 29, 2020, 03:38 |
Rep Power: 8 |
OpenFOAM supports following file formats:
File extension Format description .ftr OpenFOAM triangulated format .stl Stereolithography (STL), ASCII .stlb Stereolithography (STL), binary .obj Wavefront object (OBJ) .off 3D Object File Format (OFF) .vtk Visualisation Toolkit (VTK) .tri Triangle format .ac Inivis AC3D .smesh TenGen surface mesh format .gts Midas Geotechnical & Tunnel analysis System (GTS) .dx OpenDX format |
cad format |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
