Creation of boundaryData for turbulentDigitalFilterInlet
Old   October 13, 2020, 02:49
Default Creation of boundaryData for turbulentDigitalFilterInlet
Bazinga is on a distinguished road
I am looking for a way to create patch-profile input for the turbulentDigitalFilterInlet inlet type as mentioned here:
https://www.openfoam.com/documentati...-dfm-fsm-usage
I understand that I can create inlet profiles of the mean velocity and Reynolds stresses. I have the values of the profiles in a csv format but I am not sure how the create the proper files in constant/boundaryData/<patch Name/...
Bazinga is offline   Reply With Quote
Old   July 15, 2021, 07:20
Tom Lauriks
Tom Lauriks is on a distinguished road
to my understanding, there should be in the patch name dir, a points file. It should contain the coordinates, e.g.:
( -1.5 0 0.0 )
( -1.5 0 0.0015102 )
( -1.5 0 0.119958 )
( -1.5 0 0.123124 )
I think that the coordinates can be any values, but of course, they do have to fall within your domain. I've used python and linux bash to create scripts that convert my coordinates into a file with the above shown format. Note that these coordinates describe a profile across the height at x=-1.5 and y=0.
Then in patch name/0, there should be a file containing the reynolds stresses - R - (but I believe that you can also define them as uniform across the patch) and a file containing the velocity - UMean - at the points corresponding to the coordinates described in points, e.g. for R I have:
( 0.000000e+00 0.000000e+00 -0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00 )
( 7.803253e-02 0.000000e+00 -1.512301e-02 5.737909e-02 0.000000e+00 2.234312e-02 )
( 6.004497e-01 0.000000e+00 -1.293823e-01 3.694919e-01 0.000000e+00 2.414780e-01 )
( 5.990021e-01 0.000000e+00 -1.301567e-01 3.693150e-01 0.000000e+00 2.433442e-01 )
where you have to follow the format of a symmetric tensor in openfoam (see description here https://www.openfoam.com/documentati...ymmTensor.html). Also the for the R and UMean file, I made scripts in python and linux bash to convert the data that I have, into the format with the brackets.
Tom Lauriks is offline   Reply With Quote
generation of boundaryData files for timeVaryingMappedFixedValue MartinEB OpenFOAM Programming & Development 5 June 3, 2020 19:11
Creating boundaryData folder for timeVaryingMappedFixedValue boundary condition Sid! OpenFOAM Running, Solving & CFD 2 October 4, 2017 01:44
Creation of a plane surface with the TUI EmiS FLUENT 2 August 31, 2016 08:11
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
about rate of species creation and depletion shao FLUENT 1 July 8, 2002 15:21
