blockMeshDict in Sandia_LTS combustion/reactingFoam/RAS tutorial
Old   January 28, 2021, 13:12
Default blockMeshDict in Sandia_LTS combustion/reactingFoam/RAS tutorial
Domenico Lahaye
dlahaye is on a distinguished road
I have a doubt on the blockMeshDict to define the geometry in the Sandia_LTS combustion/reactingFoam/RAS tutorial.
The blockMeshDict file is here: https://github.com/OpenFOAM/OpenFOAM.../blockMeshDict
My question is as follows:
The inletPilot faces is defined as (5 3 4 6) (line 110)
The second of the wallTube patches is defined as (10 11 9 8) (line 99)
On both faces the outward normal is in the negative z-direction. The nodes of both faces are traversed in opposite direction.
Why is this? Thx.
dlahaye is offline   Reply With Quote
Old   January 29, 2021, 09:03
Petros Ampatzidis
petros is on a distinguished road
Hi Domenico,
From a quick look it seems that face's (5 3 4 6) normal is towards the negative z-direction whereas the one of face (10 11 9 8) is towards the positive z-direction. I hope I am not misreading the blockMeshDict.
Best,
Petros
petros is offline   Reply With Quote
Old   January 29, 2021, 13:44
Domenico Lahaye
Dear Petros,
Sincere thanks.
I fail however to understand why on face (10 11 9 8) the normal is towards the positive z-direction.
Could you pls. elaborate?
Greetings, Domenico.
Old   January 29, 2021, 15:40
Petros Ampatzidis
Hi Domenico,
Sorry for being misunderstood. When I said that the normal of face (10 11 9 8) points in the positive direction I was refering to the one that matches the order in which its vertices are traversed in the tutorial. I agree that since face (10 11 9 8) belongs to block (8 10 11 9 17 19 20 18) I would traverse its vertices as (10 8 9 11).
I think I have encountered similar mis-orientated faces. If I remember correctly blockMesh gives a fatal error only when all faces of a block are pointing inwards.
The question is what really happens if one or two faces are pointing inwards and how that affects calculations. I am not sure about it so I hope some more experienced users can shed some light.
Best,
Petros
Old   January 31, 2021, 07:24
Domenico Lahaye
Dear Petros,
Thank you for sharing your thoughts.
It is wonderful to hear that my doubts on the issue are shared by you.
I will seek further support.
Thanks again, Domenico.
tutorial files KITetima FLUENT 8 November 23, 2019 16:05
AMI - Propeller Tutorial diverging kingmaker OpenFOAM Running, Solving & CFD 2 November 4, 2016 02:57
[Other] blockMeshDict not Matching Boundary HassanDarian OpenFOAM Meshing & Mesh Conversion 0 March 19, 2014 13:30
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR MAE7509 FLUENT 0 January 22, 2014 20:59
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
