Boundary & Initial Conditions for turbulence model |
January 23, 2022, 16:10 |
Hello Everybody,
I am new to OpenFoam and have the task to simulate in OpenFoam a turbulent round jet. I generated the mesh as a axisymmetry blockMesh with a nozzle and a open domain for the free flow. The nozzle outlet diameter is 10 mm and I want to get high Reynolds number at the outlet to compare the values with table 2 (https://www.diva-portal.org/smash/ge...FULLTEXT01.pdf) Actually I am not sure how to specify the boundary conditions and initial conditions for the open domain. As basis I suggested to use the FOAMTUTORIAL flowWithOpenBoundary. I specified every patch of the domain which is beeing the outlet like the atmosphere from the tutorials. That means: k /Omega -> inletOutlet; inletValue uniform $Inlet; value uniform $Inlet; nut -> calculated; uniform 0; p ->totalPressure; p0 uniform 0; value uniform 0; U-> pressureInletOutletVelocity; value uniform (0 0 0); I don't understand which value I should use for the k and omega. For the simulation I specified fixedValues for the nozzle outlet to get a turbulent flow but this couldn't be the same values. Which value do I need for a atmosphere? I hope you could help me with my problem. Kind regards, Noob |
February 25, 2022, 10:14 |
Bas Nieuwboer
Rep Power: 13 |
This website shows how to relate your turbulent quantities to the velocity: https://www.cfd-online.com/Wiki/Turb...ary_conditions
For turbulent inlets (in RANS modelling) you can use 'turbulentIntensityKineticEnergyInlet' for your turbulent kinetic energy. It computes this based on the equations provided in the website. https://www.openfoam.com/documentati...alarField.html) Similarly, you can use 'turbulentMixingLengthFrequencyInlet' for the dissipation rate omega. (https://www.openfoam.com/documentati...frequency.html) For the atmosphere, I would use inletOutlet |
flowwithopenboundarys, openfoam |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
