Time-varying boundary condition
Like Tree17Likes
Old   July 26, 2013, 09:39
Default Time-varying boundary condition
Yuri Frey
yurifrey is on a distinguished road
Hello!
I am a new OpenFoam user and I am trying to set up a case with time-dependent boundary condition for velocity. In the tutorial I found something but it's not working.. In the "0" folder I wrote the file "U" for velocity specifying the inlet condition :
inlet
{type uniformFixedValue;
uniformValue table
(0 0)
(2.0 1.0)
I thought this was the way to say I have a uniform inlet profile which goes from 0 m/s to 1 m/s between time t=0 and t=2, but when I start icoFoam this is what I get:
--> FOAM FATAL IO ERROR:
Expected a '(' while reading VectorSpace<Form, Cmpt, nCmpt>, found on line 49 the label 0
file: /home/yurifrey/Scrivania/tesi/aorta/0/U.boundaryField.inlet.uniformValue at line 49.
From function Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM exiting
Wish someone can help me,
thank you very much,
Yuri
yurifrey is offline   Reply With Quote
Old   July 26, 2013, 09:49
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Velocity is a vector so table should contain vectors (1 0 0). You put there scalars, and it is the reason for OpenFOAM to complain.
Table should be something like:
uniformValue table
(0 (0 0 0))
(2.0 (1.0 0 0))
alexeym is offline   Reply With Quote
Old   July 26, 2013, 10:00
Yuri Frey
Thank you very much!
Old   July 27, 2013, 05:20
Yuri Frey
Just another little question.. What if I want the velocity to be directed normal to the boundary, instead of giving the components of the vector? I tried
{type surfaceNormalFixedValue;
refValue uniform table
(0 0)
(2 -1)
Thank you again!
Yuri
Old   July 27, 2013, 07:51
Alexey Matveichev
AFAIK uniformFixedValue BCs are implemented only for limited types of boundary conditions (http://www.openfoam.org/version2.1.0...conditions.php).
Though it is rather simple to implement your own boundary condition. For example you can change surfaceNormalFixedValue. Instead of
class surfaceNormalFixedValueFvPatchVectorField
    public fixedValueFvPatchVectorField
    // Private data
        scalarField refValue_;
you put something like
class surfaceNormalUniformFixedValueFvPatchVectorField
    // Private data
        autoPtr<DataEntry<Type> > refValue_;
and reimplement operator = to use new time dependent reference value.
fumiya likes this.
Old   October 5, 2014, 21:28
Lightbulb
maysmech's Avatar
maysmech is on a distinguished road
Hello
I need varying BC for interstitialInletVelocity which can be found in DPMFoam/Goldschemidt. Using table for fixed value:
bottom
    uniformValue table
        (0 (0 0 1))
        (0.001 (0 0 2))
        (0.002 (0 0 3))
        (0.003 (0 0 4))
the run starts without error. But for interstitialInletVelocity"
The default is:
    bottom
        type            interstitialInletVelocity;
        inletVelocity   uniform (0 0 1);
        value           uniform (0 0 1);
        phi             phi.air;
        alpha           alpha.air;
trying to time varying it by:
    bottomSB
        inletVelocity   uniformFixedValue;
    uniformValue table
        (0 (0 0 1))
        (0.001 (0 0 2))
        (0.002 (0 0 3))
        (0.003 (0 0 4))
        value           table
        (0 (0 0 1))
        (0.001 (0 0 2))
        (0.002 (0 0 3))
        (0.003 (0 0 4))
        phi             phi.air;
        alpha           alpha.air;
gives this error:
expected keyword 'uniform' or 'nonuniform', found table
file: /home/user/OpenFOAM/user-2.3.0/run/tutorials/lagrangian/DPMFoam/test/0/U.air.boundaryField.bottom from line 52 to line 70.
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/user/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C at line 304.
FOAM exiting
Change of second "table" to "nonuniform" also gives error:
wrong token type - expected Scalar, found on line 64 the punctuation token '('
file: /home/user/OpenFOAM/user-2.3.0/run/tutorials/lagrangian/DPMFoam/test/0/U.air.boundaryField.bottom.value at line 64.
    From function operator>>(Istream&, Scalar&)
    in file lnInclude/Scalar.C at line 93.
FOAM exiting
I checked other changes by "Banana" trick debugging but it doesn't work. This boundary condition is suitable for two phase flows because It consider the inlet porosity so we will sure about fixed value of inlet flow rate. It is not possible to use simple fixed value BC and should use interstitialInletVelocity instead. If anyone know about time varying this BC please share here.
Best,
maysmech is offline   Reply With Quote
Old   October 12, 2014, 12:47
Retired Super Moderator
Bruno Santos
Greetings to all!
@Maysam: Unfortunately I don't have enough time to give the whole solution, but I think I can still give information on why that didn't work and what can be done to fix the problem.
  1. "uniformFixedValue" is a special boundary condition, derived from "fixedValue". This is the reason why it's possible to use it to define values based on tables and polynomials and so on: http://www.openfoam.org/version2.1.0...conditions.php - and as explained on that page, this feature is possible thanks to another new feature they added in OpenFOAM 2.1.0, namely the "DataEntry" class.
  2. "interstitialInletVelocity" is similar to "fixedValue". Which is why it's not able to handle the time-based tables.
  3. The solution is to create a new boundary condition derived from "interstitialInletVelocity", almost the same way that "uniformFixedValue" is derived from "fixedValue". Online you can find the source code folders for these 3 BCs (in OpenFOAM 2.3.x):
  4. Instructions on how to create a new BC... there are several online... just Google:
    openfoam create new boundary condition
    and you'll find several links.
Best regards,
Bruno
Chanikya_Valeti likes this.
Old   October 12, 2014, 23:04
Question
maysmech's Avatar
Thanks Bruno, Do you know what is the difference between "inletVelocity" and "value" in this BC?
fixedValue and uniformFixedValue value need one velocity but this on needs two.
Old   October 18, 2014, 14:55
Bruno Santos
Hi Maysam,
If you learn a bit about C++ and reading OpenFOAM source code, you could easily see the following details:
  1. If you look at the file "src/finiteVolume/fields/fvPatchFields/derived/interstitialInletVelocity/interstitialInletVelocityFvPatchVectorField.C": https://github.com/OpenFOAM/OpenFOAM...hVectorField.C
  2. Then look at this part of the code in that file:
    void Foam::interstitialInletVelocityFvPatchVectorField::updateCoeffs()
        if (updated())
            return;
        const fvPatchField<scalar>& alphap =
            patch().lookupPatchField<volScalarField, scalar>(alphaName_);
        operator==(inletVelocity_/alphap);
        fixedValueFvPatchVectorField::updateCoeffs();
  3. You'll see that the "value" field isn't directly used during the simulation. In fact, the value in "value" should be the result of "inletVelocity_/alphap"... therefore, "value" acts as the current representation of the velocity field for the current time instance or iteration.
  4. "inletVelocity" is the actual desired velocity for this inlet
Best regards,
Bruno
enthusiast likes this.
Old   October 19, 2014, 01:06
maysmech's Avatar
Hi Bruno,
I know the difference between u and U, the actual and superficial velocity with relation of U=alpha*u.
This is the main advantage of "interstitialInletVelocity" to "fixedValue" and "uniformFixedaValue". My question was about why there are two entries in 0/U.air
bottom
inletVelocity uniform (0 0 1.875);
value uniform (0 0 1.875);
phi phi.air;
alpha alpha.air;
However I found the answer. The second entry is a dummy value for 0 value reading in paraView. So I should try to use table for first entry "inletVelocity uniform (0 0 1.875);" and modify the source code. I have started to create the new boundary condition based on your comment but have faced to some problems because of C++ knowledge. I will bring the modifications to share with others to write the time varying interstitialInletVelocity BC.
wyldckat likes this.
Old   October 21, 2014, 17:26
maysmech's Avatar
We want use available boundary conditions of fixedValue (BC1), uniformFixedValue (BC2) and interstitialInletVelocity (BC3) to write own myInterstitialInletVelocity (BC4).
BC4 will have advantages of BC3 (which accounts alpha to have constant mass flow rate in multiphase flows) and BC2 (which accepts table to apply time varying air velocity).
The first step is compiling BC in user directory.
1- Copying BC3 from source to user directory and renaming it to my0InterstitialInletVelocity.
$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/interstitialInletVelocity
to
$WM_PROJECT_USER_DIR/src/finiteVolume/fields/fvPatchFields/derived/my0interstitialInletVelocity
2- Modifying .H and .C files with new name.
3- Writing an appropriate Make/files and options and then compiling it in:
4- Adding this dictionary to controlDict:
libs ("libmyFiniteVolume.so");
In these links the src folder and a test case are available. After extracting it in user directory it needs compile by wmake.
The link of GoldschemidtBC contains my0InterstitialInletVelocity BC in 0/U.air and dictionary in it is controlDict.
The src link contains BC1 to BC4. but is compiled for "my0InterstitialInletVelocity".
The BC4 doesn't work which will be discussed later.
https://www.dropbox.com/s/b54r786b167bmxw/src.tar.gz?dl=0
https://www.dropbox.com/s/8fpj3os65a8hnp9/GoldschmidtBC.tar.gz?dl=0
The next step is doing modification in
myInterstitialInletVelocity (BC4) to possible accepting table.
The difference of BC2 to BC1 are:
1- BC2 has a new parameter definition:
const Field<Type>& fld
which I think it is for the new variable:
uniformValue_()
I define uniformInletVelocity_ in BC4 too
2- BC1 uses mapper (which I don't know what does it do):
fixedValueFvPatchField<Type>::fixedValueFvPatchField
    const fixedValueFvPatchField<Type>& ptf,
    const fvPatch& p,
    const DimensionedField<Type, volMesh>& iF,
    const fvPatchFieldMapper& mapper
    fvPatchField<Type>(ptf, p, iF, mapper)
    if (&iF && mapper.hasUnmapped())
        WarningIn
            "fixedValueFvPatchField<Type>::fixedValueFvPatchField\n"
            "(\n"
            "    const fixedValueFvPatchField<Type>&,\n"
            "    const fvPatch&,\n"
            "    const DimensionedField<Type, volMesh>&,\n"
            "    const fvPatchFieldMapper&\n"
            ")\n"
        )   << "On field " << iF.name() << " patch " << p.name()
            << " patchField " << this->type()
            << " : mapper does not map all values." << nl
            << "    To avoid this warning fully specify the mapping in derived"
            << " patch fields." << endl;
but BC2 uses bypass mapper with the new variable of uniformValue_ :
template<class Type>
uniformFixedValueFvPatchField<Type>::uniformFixedValueFvPatchField
    const uniformFixedValueFvPatchField<Type>& ptf,
    const fvPatch& p,
    fixedValueFvPatchField<Type>(p, iF),  // bypass mapper
    uniformValue_(ptf.uniformValue_().clone().ptr())
    // Evaluate since value not mapped
    const scalar t = this->db().time().timeOutputValue();
    fvPatchField<Type>::operator==(uniformValue_->value(t));
I think it uses bypass mapper of BC1 and doesn't rewrite it here. However what we are seeking is seen here (time).
3- we see time again in next class. In this one, it is looking for value or table:
    const fvPatch& p,
    const dictionary& dict
    uniformValue_(DataEntry<Type>::New("uniformValue", dict))
    if (dict.found("value"))
        fvPatchField<Type>::operator==(Field<Type>("value", dict, p.size()));
    else
4- The last difference is "clone" which is added to BC2 and again I don't know what it is.
However, I tried many different tries and errors by adding classes to BC4 but not possible to compile it successfully.
Two possibles for errors are:
1- mistakes in defining parameters
2- two "operator== ..." in updateCoeff of BC4:
void Foam::myInterstitialInletVelocityFvPatchVectorField::updateCoeffs()
Info << "Banana1" <<endl;
    if (updated())
        return;
    const scalar t = this->db().time().timeOutputValue();             //
    fvPatchField<vector>::operator==(uniformInletVelocity_->value(t));  //
   // fixedValueFvPatchField<Type>::updateCoeffs();                     //
    operator==(uniformInletVelocity_/alphap);
It needs to check two things for update: alpha and uniformInletVelocity. Again I tried different configurations (separated, together, ...) but it doesn't compile at all
Sorry for this long post and thanks in advance for any suggestion.
Sakun likes this.
Old   November 3, 2014, 18:24
Lightbulb
  #12
maysmech's Avatar
I am trying to write a time varying boundary condition which accounts inlet porosity in applying inlet velocity but it hasn't lead to solution yet.
Is it possible to write a script which automatically do below procedure:
1- Run
2- After finishing run (reaching to endTime) do the following:
2-1- Iincrease endTime in system/controlDict (for example from 1 to 2)
2-2- Change inlet velocity in U.air file (with known line and column) in exist latest time folder.
3- Run again and do a loop from 1 to reach a desired time (for example 10sec).
For this purpose we should have a script to:
1- change a number in a file
2- understand when the run is finished
3- loop over time
I think the first one is possible but I don't know about 2 and 3.
Any idea will be appreciated.
Old   November 4, 2014, 05:27
anonymous
ssss is on a distinguished road
Why don't you use groovyBC for your custom boundary condition?
You seem to be making it a lot more complicated than what it really is, search for groovyBC I'm sure it will help you.
ssss is offline   Reply With Quote
Old   November 5, 2014, 16:31
Question
  #14
Charlie
mechem is on a distinguished road
Hi maysmech,
This is what exactly I need for finding minimum fluidization velocity.
I need a gradually increase in fluidization velocity.
I used table with fixed value but the results was mistake because of inlet porosity is not considered in fixedValue.
Did you find any solution? Please share it if you have found.
Best regards.
mechem is offline   Reply With Quote
Old   November 6, 2014, 17:55
Question
  #15
maysmech's Avatar
Groovy boundary condition doesn't work with such boundary condition, as far as I know.
The type of boundary condition is interstitialInletVelocity which divide velocity over air volume fraction.
The groovy doesn't see volume fraction and is suitable for fixed value types.
If I'm wrong, please correct!
Originally Posted by mechem View Post
Hi maysmech,
Best regards.
Hi Charlie,
As you mentioned, gradually increase of velocity is crucial for any fluidizeation velocity simulation.
But unfortunately I didn't find any solution yet
Last edited by wyldckat; November 8, 2014 at 06:39. Reason: merged posts that were in different threads but that were also pulled into this thread
Old   November 23, 2014, 14:35
Question
  #16
maysmech's Avatar
Thanks Bruno for merging these threads.
If anyone has any Idea for first (BC4) or second (script) way it will be appreciated to share with others.
Regards,
Old   November 24, 2014, 08:04
anonymous
As far as I'm concerned, you can access volume fraction and all the variables you want from groovyBC.
Old   November 30, 2014, 16:15
Bruno Santos
Greetings to all!
@Maysam: I didn't manage to have enough time to fully test this, so please test if everything is working OK. The new boundary condition, use/build instructions and tutorial cases are provided here: https://github.com/wyldckat/Unsuppor...OpenFOAM-2.3.x
Either use "git clone" or download as a ZIP file, as instructed on the right side of the page at that website.
By the way, the main detail was that the method "updateCoeffs()" should be like this:
void Foam::uniformInterstitialInletVelocityFvPatchVectorField::updateCoeffs()
    if (updated())
        return;
    inletVelocity_ = uniformInletVelocity_->value(t);
By the way, if you're wondering how long it took me to develop this: around 2 hours.
Best regards,
Bruno
lenzo and Farid like this.
Old   November 30, 2014, 16:20
maysmech's Avatar
Hi Bruno,
Thank you very much for spending your valuable time on this issue.
I checked. it works perfect.
Best regards,
Old   December 8, 2014, 13:25
Bruno Santos
Hi Maysam,
Just a side note: Sorry, I wasn't very clear on why I mentioned it took me 2 hours.
My estimate is that on average it takes me 20 minutes to answer each question here on the forum, although finding/developing the answer can sometimes take 6 to 8 hours or more... so the average comes down only because there are several posts where the answer ends up being a questions.
Therefore, the concept I had in mind when I said "2h" was that it was all of the time I had that day and that compared to the average it was 5 other posts I couldn't answer...
I wasn't trying to show off "how good I am", I was actually trying to state that I'm not good enough to answer as fast as I wanted to be able to
This to say: If you - and anyone reading this post - can find some time to help other newcomers on the forum, please do!
Best regards,
Bruno
PS: I'm very glad it's working!!
lenzo and allanZHONG like this.
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
Time Varying Boundary Conditon ashish CFX 3 February 15, 2005 06:21
