why can not define a variable of "scalarFieldField tspecies(19)"
Old   December 10, 2013, 09:25
Default why can not define a variable of "scalarFieldField tspecies(19)"
赵庆良
zqlhzx is on a distinguished road
Hi foamer.
I want to define "scalarFieldField tspecies(19)",code as following:
 #include "scalarFieldField.H"
scalarFieldField tspecies(19);
    for (label i=0; i<Y.size(); i++)
                  tspecies[i](tableProperties.lookup(Y[i].name()));
however,it gave me error:
readTableProperties.H: In function ‘int main(int, char**)’:
readTableProperties.H:28:1: error: ‘scalarFieldField’ was not declared in this scope
readTableProperties.H:28:18: error: expected ‘;’ before ‘tspecies’
readTableProperties.H:34:19: error: ‘tspecies’ was not declared in this scope
How can I solve the problem?
Thank in advance!
zqlhzx is offline   Reply With Quote
Old   December 10, 2013, 10:38
Lieven
Lieven will become famous soon enough
The way I understand it, is that scalarFieldField does not define a type like e.g. scalarList. So you can't create objects of this type since it simply does not exist. Instead, the source files (scalarFieldField.C and .H) define how objects of the type FieldField<Field, scalar> should handle a number of basic operations. So if you want to create an object which behaves as a scalarFieldField you should create it as
FieldField<Field, scalar> tspecies(19);
At least that's what I think ...
Lieven is offline   Reply With Quote
Old   December 10, 2013, 12:09
赵庆良
Dear Lieven,
What you think is right!
It really works for me!Thank you for you help!Good luck!
Old   December 10, 2013, 12:58
赵庆良
Dear Lieven,
I wirte the following codes in my solver and it can be compiled successfully.Could I ask you another question?
Info<< "Reading table properties\n" << endl;
    IOdictionary tableProperties
        IOobject
            "tableProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
FieldField<Field,scalar> tspecies(19);
                  scalarField A(tableProperties.lookup("Y[i].name()"));
                  tspecies[i]=A;
What I'd like to ask you is something about "(tableProperties.lookup("Y[i].name()")".In my tableProperties ,it is :
FoamFile
version     2.0;
format      binary;
class       dictionary;
location    "constant";
object      tableProperties;
CH4
0.0000    0.0120    0.0240    0.0360    0.0480    0.0060    0.0720    0.0840    0.0960    0.1080
0.1200    0.1320    0.1440    0.1560    0.1680    0.1800    0.1920    0.2040    0.2160    0.2280
0.2400    0.2520    0.2640    0.2760    0.2880    0.3000    0.3120    0.3240    0.3360    0.3480
0.3600    0.3720    0.3840    0.3960    0.4080    0.4200    0.4320    0.4440    0.4560    0.4680
0.4800    0.5000    0.5250    0.5500    0.5750    0.6000    0.6250    0.6500    0.6750    0.7000
0.7250    0.7500    0.7750    0.8000    0.8500    0.9000    0.9500    1.0001
O2
CO2
H2O
(In fact,the values in different species is different.I just show it as example).It should be that Y[0].name()=CH4,Y[1].name()=O2.Y[2].name()=CO2,Y[3].name()=H2O. I want to make "scalarFIeld A" is equal to the values for different species.
So lookup (Y[i].name).
If I use
scalarField A(tableProperties.lookup("CH4"))
it can work,and my case can run.However,if I use
then I run my case ,it give me error:
keyword Y[i].name() is undefined in dictionary "/home/acer/OpenFOAM/acer-2.2.2/run/singlefirepoolx/constant/tableProperties"
Then I get rid of the "" like:
scalarField A(tableProperties.lookup(Y[i].name()))
it still gave me error:
FOAM FATAL ERROR:
hanging pointer at index 0 (size 19), cannot dereference
From function PtrList:perator[]
in file /opt/openfoam222/src/OpenFOAM/lnInclude/PtrListI.H at line 150.
FOAM aborting
What do you think about my error?Could you give me some advises?Thank you !
UDF: trying to implement a Kinetic Equation source term er.mkumar Fluent UDF and Scheme Programming 35 March 22, 2019 10:20
Plot of user defined variable in CFD Post dreamz Main CFD Forum 0 December 8, 2013 22:00
define variable spring stiffness by writing a macro or command or.. maralll Main CFD Forum 0 November 6, 2013 20:01
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
