void Foam::multiphaseSystem::solve() of multiphaseEulerFoam solver |
December 16, 2013, 13:13 |
hi,
within method solve() can be found: Code:
... const dictionary& pimpleDict = mesh_.solutionDict().subDict("PIMPLE"); ... Code:
const fvMesh& mesh_ and solutionDict() [Return the selected sub-dictionary of solvers if the "select" keyword is given, otherwise return the complete dictionary.] : Code:
const Foam::dictionary& Foam::solution::solutionDict() const 344 { 345 if (found("select")) 346 { 347 return subDict(word(lookup("select"))); 348 } 349 else 350 { 351 return *this; 352 } 353 } and subDict("PIMPLE") [Find and return a sub-dictionary for manipulation.] Code:
Foam::dictionary& Foam::dictionary::subDict(const word& keyword) 617 { //lookupEntryPtr(...): //Find and return an entry data stream pointer for manipulation if present otherwise return //NULL. If recursive, search parent dictionaries. If patternMatch, use regular expressions. 618 entry* entryPtr = lookupEntryPtr(keyword, false, true); 619 620 if (entryPtr == NULL) 621 { 622 FatalIOErrorIn 623 ( 624 "dictionary::subDict(const word& keyword)", 625 *this 626 ) << "keyword " << keyword << " is undefined in dictionary " 627 << name() 628 << exit(FatalIOError); 629 } 630 return entryPtr->dict(); 631 } 1A. mesh_ is a reference to the fvMesh which consists of many subobjects. When calling method solutionDict() on mesh_ what is method found("select") actually doing and if it is searching for the word "select" where in fvMesh mesh it is searching for it? 1B. Method solutionDict() : What is exactly meant by the "select" keyword? solutionDict() does not get any input parameters and therefore I assume it is really searched for a dictionary called "select"... 2. Assumed method solutionDict() returns the reference to mesh, hence mesh_ (see line 349 to 351 second code snippet) method subDict("PIMPLE") afterwards searches for a dictionary called "PIMPLE" in fvMesh mesh? Perhaps I am misinterpreting something here? I hope someone enlightens me . greetings maybee |
November 5, 2017, 09:11 |
rik houthuys
Rep Power: 9 |
Hello Maybee,
Did you find answers for your questions here? |
November 5, 2017, 11:30 |
I am not sure since I worked with the solver a long time ago, but I don t think I could get any answers to these questions. Best Regards |
Sliding Interface issues | philippose | OpenFOAM Running, Solving & CFD | 7 | May 5, 2014 03:13 |
Unexplained Error during Solver Runs | cfb | CFX | 6 | November 9, 2012 15:42 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
