Different errors when linking custom library via solver vs controlDict |
February 21, 2014, 03:12 |
Christian Butcher
Rep Power: 13 |
So, I'm currently working my way through the hexRef, dynamicRefineFvMesh and refinementHistory group of files, and have gotten some way (I hope) towards making it work.
However, when I run the solver, I encounter a segmentation fault. My library is linked into the Make/options file of my solver, so I do not generally list it in the controlDict libs() section, but being curious, I added it to controlDict, and got a (different) segfault error. I post the comparison of the errors below: Code:
With library listed in controlDict hexRef4::setRefinement : Splitting faces hexRef4::setRefinement : Adding edge splits to unsplit faces hexRef4::setRefinement : Changing owner/neighbour for otherwise unaffected faces hexRef4::setRefinement : Create new internal faces for split cells Refined from 9 to 36 cells. #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::PtrList<Foam::fvsPatchField<double> >::~PtrList() at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/PtrList.C:133 (discriminator 1) #4 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::~GeometricField() at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/DimensionedField.C:276 (discriminator 1) #5 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::~GeometricField() at ~/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/GeometricField.C:654 #6 Foam::surfaceInterpolation::clearOut() at ??:? #7 Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&) at ??:? #8 Foam::dynamicRefineFvMeshHexRef4::refine(Foam::List<int> const&) at ??:? #9 Foam::dynamicRefineFvMeshHexRef4::update() at ??:? #10 at ~/OpenFOAM/christian-2.2.2/application/solver/multiphase/myInterFoam/myInterDyMFoam/myInterDyMFoam.C:92 (discriminator 1) #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 at ??:? Segmentation fault (core dumped) ------------------------------------------------------------------------------------------------------------------ Without library listed hexRef4::setRefinement : Splitting faces hexRef4::setRefinement : Adding edge splits to unsplit faces hexRef4::setRefinement : Changing owner/neighbour for otherwise unaffected faces hexRef4::setRefinement : Create new internal faces for split cells Refined from 9 to 36 cells. Found 42 split faces iter* = 1 correctFluxes_ = 6 ( #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::OSstream::write(Foam::word const&) at ??:? #4 Foam::operator<<(Foam::Ostream&, Foam::word const&) at ??:? #5 Foam::Ostream& Foam::operator<< <Foam::word, Foam::word, Foam::string::hash>(Foam::Ostream&, Foam::HashTable<Foam::word, Foam::word, Foam::string::hash> const&) at ??:? #6 Foam::dynamicRefineFvMeshHexRef4::refine(Foam::List<int> const&) at ??:? #7 Foam::dynamicRefineFvMeshHexRef4::update() at ??:? #8 at ~/OpenFOAM/christian-2.2.2/application/solver/multiphase/myInterFoam/myInterDyMFoam/myInterDyMFoam.C:92 (discriminator 1) #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 at ??:? Segmentation fault (core dumped) Code:
HashTable<surfaceScalarField*> fluxes ( lookupClass<surfaceScalarField>() ); correctFluxes_ is the internal variable which holds these pairings, and if I enter suitable Info<< or Pout<< lines then I can get a nicely formatted list of pairs within the readDict() function, or any time before I call meshCutter_.setRefinement(cellsToRefine, meshMod, normalVector);. (Here you'll notice that I have a 3rd parameter to my call, this is because the aim is to refine in 2D). dynamicRefineFvMeshHexRef4.C is almost identical to dynamicRefineFvMesh.C, the standard OF implementation, and in particular the section which is throwing errors is exactly identical. I am unsure if meshCutter_.setRefinement is supposed to clear the correctFluxes_ hashTable, and in the assumption it is not, then presumably my hexRef4.C file has (more!) problems. Anyway, correctFluxes_ no longer holds the pairs, and so the iterator is immediately beyond the values available to print, leading to the 2nd error. I have no idea why the two situations should behave differently? They both include the same library, and run on the same code, but if I link in controlDict, it crashes maybe 20 lines earlier, to a probably(?) related issue, but not quite the same. Any help would be much appreciated. |
library solver linking |
Display Modes | |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Forces not calculated when including a library in controlDict | fusij | OpenFOAM | 2 | May 13, 2011 07:25 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Solver stops abruptly without errors | prabhu | CFX | 1 | December 20, 2007 01:35 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
