kOmegaSST with lowRe-damping (as in Fluent)
Like Tree21Likes
Old   April 24, 2014, 08:31
Default kOmegaSST with lowRe-damping (as in Fluent)
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I added some functions to the kOmegaSST model, that are called "low Reynolds number corrections" in the Fluent manual. Unfortunately, I don't get the same results as in Fluent, so obviously I did something wrong .
I tried to make everything as "fluent-like" as possible, so I used all the constant names and so on as in Fluent. I added a few functions (all these alphaStar, alphaStarZero, betaStar, ...) and changed a bit in the differential equations.
For debugging I used a periodic pipe flow (3D).
1) In the standard OpenFoam kOmegaSST model, I get nearly exactly the same results for k,omega,nut and U, as for the Fluent version (with deactivated "low Re corrections").
2) In the new lowRe model I get k-values and nut-values about a factor of 3 lower than in Fluent. I didn't compare omega and U here.
If anyone also wants to use this model, I would be happy about any debugging help. I attached the files to this post.
kOmegaSST_lowRe.C
kOmegaSST_lowRe.H
I could easily compile these functions by creating a directory "kOmegaSST_new" with the two sub-directories "k_omegaSST_lowRe" (<- place the .H and .C file here) and "Make". In "Make", create two files, one called "files" and one called "options".
"files" looks like:
kOmegaSST_lowRe/kOmegaSST_lowRe.C
LIB = $(FOAM_LIBBIN)/libMyIncompressibleRASModels
and "options" looks like:
EXE_INC = \
    -I$(LIB_SRC)/turbulenceModels \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude
LIB_LIBS = \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lfiniteVolume \
    -lmeshTools
For compiling I go into the main directory and type "wmake libso".
Then, in my OpenFoam case I change the controlDict libs to
libs
    "libOpenFOAM.so"
    "libincompressibleTurbulenceModel.so"
    "libMyIncompressibleRASModels.so"
    "libincompressibleRASModels.so"
and the RASProperties to
RASModel        kOmegaSST_lowRe;
k at the wall is set to 1e-12, nut to calculated and omega to omegaWallFunction.
Edit: These are results for the regular OpenFoam model and Fluent without low-Re damping I am talking about at "1)". The grid size is y+ = 0.44 at the pipe wall.
jherb, lt.quibbler, xpqiu and 4 others like this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 7, 2014, 11:55
Park sangbin
sangbin.hana is on a distinguished road
Thank you for your help thanks
sangbin.hana is offline   Reply With Quote
Old   May 13, 2014, 03:25
Philipp
Hey guys,
I am glad to tell you that it works now. I made two comparisons between Fluent and my low-Re version in OpenFoam and they match!
After some debugging I found two errors in the Fluent manual but have a look:
Channel Flow:
Old   May 13, 2014, 03:26
Philipp
Pipe Flow:
Old   May 13, 2014, 03:29
Philipp
New version (1.0) of the OpenFoam model.
kOmegaSST_lowRe_V1.0.zip
By the way: This is from Fluent version 15.0, incompressible flow,
boundary conditions for walls are:
U=(0,0,0), p=zeroGradient, k=1e-12, omega=omegaWallFunction, nut=calculated (or 0)
If you use it and find some bugs, please post!
Ohbuchi, kiddmax, fumiya and 10 others like this.
Old   May 13, 2014, 03:52
hana
bluenail is on a distinguished road
I appreciate your support Thanks
k-w model is more powerful than k-e model in specific type of reactor
So, I will use this.
I have some question,
During your work, what is tool to edit your code?
Eclipse or Qt-creator or text based?
I hope you post more valuable thing about openfoam. Thanks
bluenail is offline   Reply With Quote
Old   May 13, 2014, 04:07
Philipp
Hi, I use gedit in ubuntu.
Old   May 13, 2014, 04:16
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi Philip,
I am trying to compile the code, its giving the error message.
the message is:
/kOmegaSST_lowRe$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file kOmegaSST_lowRe/kOmegaSST_lowRe.C
SOURCE=kOmegaSST_lowRe/kOmegaSST_lowRe.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/cerecam/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/kOmegaSST_lowRe.o
kOmegaSST_lowRe/kOmegaSST_lowRe.C: In member function ‘virtual void Foam::incompressible::RASModels::kOmegaSST_lowRe:: correct()’:
kOmegaSST_lowRe/kOmegaSST_lowRe.C:495:28: error: ‘GName’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/kOmegaSST_lowRe.o] Error 1
can you please tell me, what i need to change.
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   May 13, 2014, 04:30
Philipp
Hi Sivakumar,
Please have a look here:
http://www.cfd-online.com/Forums/ope...tml#post469730
It seems that you are facing an error because you use version 2.1 and not 2.3 like me.
I hope that helps.
Old   June 1, 2014, 13:34
Pete Bachant
pbachant is on a distinguished road
This is great, thanks! Have you compared this to the foam-extend-3.0 kOmegaSST_lowRe model?
Also, you may want to put this up on GitHub or similar to make it easier to distribute new versions and collaborate on new developments.
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   June 2, 2014, 02:54
Philipp
Pete, I didn't know they also have a version. But I just had a look and it is not the same. It seems that they integrated the omega boundary condition into the code. I don't see any big differences to the regular kOmegaSST model. Maybe someone should correct me.
In "my" (Fluent's) version, there are several damping functions as suggested by Wilcox in his paper "Simulation of Transition with a Two-Equation Turbulence Model", AIAA Journal Vol 32 No 2 February 1994. Equations 9 - 15. The exact values are slightly changed in Fluent.
Old   November 16, 2015, 02:03
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
For anyone interested, Pete put the code on Github
https://github.com/petebachant/kOmegaSSTLowRe
ms.hashempour likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   April 27, 2016, 06:37
giammy92 is on a distinguished road
I have compiled K-Omega SST LowRe follwing instructions by github, but when I run renumberMesh or decomposePar, i have this warning:
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /home/gianmichele/OpenFOAM/gianmichele-3.0.1/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleRASModels.so: undefined symbol: _ZTIN4Foam29incompressibleTurbulenceModelE
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libmyIncompressibleRASModels.so"
Does it mean library isn't loaded? How resolve it?
giammy92 is offline   Reply With Quote
Old   April 27, 2016, 07:13
Pete Bachant
Yep, that means the lib isn't loading. Did you get any errors when compiling?
Old   April 27, 2016, 07:57
This compare me after compiling:
gianmichele@gianmichele-K52Jc:~/OpenFOAM/gianmichele-3.0.1/kOmegaSSTLowRe$ wmake libso
Making dependency list for source file makeTurbulenceModels.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/turbulenceModels -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c makeTurbulenceModels.C -o Make/linux64GccDPInt32Opt/makeTurbulenceModels.o
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/turbulenceModels -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/finiteVolume/lnInclude -I/opt/openfoam30/src/meshTools/lnInclude -I/opt/openfoam30/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam30/src/TurbulenceModels/incompressible/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/makeTurbulenceModels.o -L/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib \
-lincompressibleTransportModels -lturbulenceModels -lfiniteVolume -lmeshTools -o /home/gianmichele/OpenFOAM/gianmichele-3.0.1/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleRASModels.so
'/home/gianmichele/OpenFOAM/gianmichele-3.0.1/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleRASModels.so' is up to date.
Old   April 27, 2016, 16:57
Pete Bachant
I was able to reproduce the warning and just pushed a commit to GitHub that should fix it. Good luck!
Old   April 27, 2016, 17:49
Thank you dear! Therefore there was an error on the library downloaded from GitHub and not an error of compilation. Now i try to recompile.
Cheers
Old   April 27, 2016, 19:10
I don't have any warning now but my values of cl and cd are very instable and after a while my results explode. Do you recommend me particular schemes?
Old   June 1, 2016, 08:15
Lee Yachao
iLyrics is on a distinguished road
I have met the same question. How do you overcome the mistake?
iLyrics is offline   Reply With Quote
Old   June 1, 2016, 08:27
Philipp
Hey,
What schemes do you use right now? How does the log file look like?
Philipp.
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 16:06
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
