how to modify the momentum eqn in a way that all dU/dx=0? |
August 8, 2014, 08:59 |
Hi everybody,
I'm trying to modify the PisoFoam in a way that all dU/dz=0. actually it's a method to reach a fully developed flow by exerting dU/dz=0 and setting the pressure gradient as a negative constant. so in momentum equation I should get rid of any dU/dz, can I do something like: Code:
fvVectorMatrix UEqn ( fvm::ddt(U) // + fvm::div(phi, U) - fvm::div(phi, myU) + turbulence->divDevReff(U) ); UEqn.relax(); if (momentumPredictor) { solve(UEqn== -theGradP); } the solver complied successfully by when I run it the following error appears Code:
--> FOAM FATAL ERROR: incompatible fields for operation [U] - [myU] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /home/mostafa/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/fvMatrix.C at line 1300. FOAM aborting any hints or tips would be appreciated. Regards, Mostafa |
August 11, 2014, 12:57 |
David Gaden
Rep Power: 22 |
You could try by creating an fvVectorMatrix with fvm::div(phi, U) first, then setting the z-component to zero, then bringing it into the full equation.
~~~ Follow me on twitter @DavidGaden |
August 11, 2014, 13:50 |
thanks for the reply.
I tried it before but I couldn't find anything that I can define a new divergence scheme. I found the below address but I got nothing from that! OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/finiteVolume/divSchemes can you please explain more about it? Regards, Mostafa p.s: should I use something like: Code:
84 tmp<fvVectorMatrix> Smagorinsky2::divDevReff 85 ( 86 volVectorField& U 87 ) const 88 { 89 volTensorField gradU(fvc::grad(U)); 90 91 volSymmTensorField aniNuEff 92 ( 93 "aniNuEff", 94 I*nuEff() + cD2_*delta()*symm(gradU) 95 ); 96 97 return 98 ( 99 - fvm::laplacian(aniNuEff, U) - fvc::div(nuEff()*dev(T(fvc::grad(U)))) 100 ); 101 } |
August 12, 2014, 04:43 |
David Gaden
Rep Power: 22 |
I don't think it's necessary to create a custom divergence scheme. What I meant was to do this all at the top-level, in your solver. Kind of like this (pseudo code):
// Create a regular matrix fvVectorMatrix divUWithoutZ(fvm::div(phi, U)); // Set the z-component to zero // Not sure exactly how off the top of my head, but it can be done // Put it in your full equation fvVectorMatrix UEqn ( fvm::ddt(U) + divUWithoutZ + turbulence->divDevReff(U) );
August 12, 2014, 05:29 |
Dear David,
That's a great idea. meanwhile, I need to exert this condition for all the dU/dz in the momentum eqn including the LES turbulent model, so I'm trying to combine the fvm::div(phi, U) and turbulence->divDevReff(U) into only turbulence->mydivDevReff() which will be defined in turbulenceModel and the LESModel. I hope using this method give me the correct solution, I doesn't I'll be here again again thanks for your consideration, Regards, Mostafa |
August 12, 2014, 09:16 |
hmmm..., I did it but again the same error:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::OSstream::write(Foam::word const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::operator<<(Foam::Ostream&, Foam::word const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/pisoFoamCS2" #6 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/pisoFoamCS2" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/pisoFoamCS2" Segmentation fault (core dumped) Code:
volVectorField myU("myU", U); forAll(myU,cellI) { scalar Ux=U[cellI].component(vector::X); scalar Uy=U[cellI].component(vector::Y); myU[cellI]=vector(Ux,Uy,0); } now I'm wondering how can I get rid of this component without using a new field? is there any way to turn this problem around? Regards, Mostafa P.S: the bigger problem is that I have grad(U) in my LES model, so I should exert this condition on it, too. therefore I probably should call something except U for my turbulence model and it's the biggest crisis!!!! because my model is unsteady and I have ddt(U) in my momentum eqn and again It would lead to having two different fields in one equation. |
August 12, 2014, 09:30 |
David Gaden
Rep Power: 22 |
You posted the stack, not the error.
Don't define myU. Use the solution I suggested.
August 12, 2014, 09:56 |
dear David,
It was the only thing I got!! No error message What do you mean "Use the solution"? Can you illuminate it more? |
August 12, 2014, 10:32 |
David Gaden
Rep Power: 22 |
Sorry I'm not clear. It's just an idea.
The first bit of code you posted, the top bit with "fvVectorMatrix UEqn"... replace that constructor with the bit of code I posted above (after tweaking). Don't define a myU. As for the LES, you may have to define a custom model because you don't have access to it at the solver level. But again, do the same thing there.
August 12, 2014, 11:23 |
thanks David,
I know what you mean and I understand where you're going, my problem is how to set the z-component to zero? I need more time to think about it and brainstorming! Regards, Mostafa |
August 17, 2014, 11:26 |
#11 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
At Mostafa's request, yesterday I finally took a look into this and after about 1h I didn't manage to figure it out. And unfortunately I currently do not have more time to look into this. Nonetheless, Mostafa still asked me this after that: Quote:
Anyway... using the User Guide as a reference, the names provided on this chapter should help us find the right keywords in the source code: http://www.openfoam.org/docs/user/fvSchemes.php The thing is that, for example, the "div" schemes are essentially just "Gauss" using an interpolation scheme, therefore one should not look for a "div" scheme to hack/modify, but rather it's the interpolation method that you should look for. Therefore, for example, you can look for a reference file that defined "linearUpwind", like this: Code:
find $FOAM_SRC -name "*.H" -type f | xargs grep linearUpwind Beyond this, there is already a lot of studying material here: http://openfoamwiki.net/index.php/OpenFOAM_guide Good luck! Best regards, Bruno
August 17, 2014, 11:58 |
#12 |
Hi Bruno,
Wooooow! that's a lot of work to do, I thought that's easy to do! everything is tied together You know, I want to solve a fully-developed turbulence flow in a channel using by a LES model. So I thought that if I can exert the dU/dx in all the equations and setting a fixed pressure gradient I can just solve a section instead of whole channel. In this way, I shouldn't wait 2 days to solve just a geometry. But it seems that solving the whole geometry would be more quicker than exerting this condition. anyway, due to the lack of time, I'll try to modify the schemes later and I certainly going to do that. Because I need the same condition for my next project. Thanks Bruno for the time you spent to find a solution for my problem and I appreciate it. It gives me a better prospective which how can I do that. Hope I can modify the schemes finally. Best Regards, Mostafa P.S: How can I run a pseudo-2D case? |
August 17, 2014, 12:23 |
#13 |
Bruno Santos
Rep Power: 128 |
An example is the very first tutorial case on the user guide: http://www.openfoam.org/docs/user/cavity.php#x5-40002.1
Modify granular temperature transport eqn HELP | tim | FLUENT | 1 | June 27, 2010 06:08 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
How to momentum eqn with bouyancy forces?? | seenu | FLUENT | 3 | March 12, 2006 16:31 |
Define new Reynolds stress term in momentum eqn. | satoshi | FLUENT | 0 | November 6, 2005 22:12 |
How to solve another continuum and momentum eqn? | west_wing | FLUENT | 0 | August 25, 2003 10:00 |
