Cells at the intersection between a plane and a patch
Like Tree1Likes
  • 1 Post By dmoroian
Old   November 18, 2014, 14:41
Default Cells at the intersection between a plane and a patch
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
I would like to be able to access the cells at the intersection between a plane and a boundary. The snippet I'm trying is:
word patchName = "surf_wall_exterior_wind_shield";
label patchID = mesh.boundaryMesh().findPatchID(patchName);
const fvPatch& cPatch = mesh.boundary()[patchID];
const labelList& patchCells = cPatch.faceCells();
const point p0(2.099,-0.714,1.099);
const point p1(2.050,-0.741,1.182);
const point p2(2.768,-0.572,1.474);
plane pl1(p0,(p1-p0)^(p2-p0));
cuttingPlane cutPlane(pl1,mesh,true);
const labelList& cutCells = cutPlane.cutCells();
label found = 0;
forAll(cutCells,cellI)//loop over the cells intersecting the plane
   forAll(patchCells, pCelli)//loop over the cells adjacent to a patch
      if(pCelli == cellI)
          alpha1[cellI] = 0.0;
          found++;
But it seems that I don't put the zeros where I actually want. Is there anyone that can identify the error?
Thanks,
Dragos
dmoroian is offline   Reply With Quote
Old   November 19, 2014, 14:13
dmoroian's Avatar
Dragos
Ok, I think the error is in the usage of the index. I will test if this is the right way:
label found = 0;
      if(patchCells[pCelli] == cutCells[cellI])
          alpha1[cutCells[cellI]] = 0.0;
          found++;
Update: tested and it works as supposed to!
arvindpj likes this.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] Conversion Error nuovodna OpenFOAM Meshing & Mesh Conversion 14 October 1, 2010 11:07
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
