Problem in Implementing a non-linear SGS model
Like Tree1Likes
Old   November 19, 2014, 23:00
Default Problem in Implementing a non-linear SGS model
Huang Xianbei
huangxianbei is on a distinguished road
Hi, all:
I want to implement a non-linear SGS model into OF. However, as I read from the source code that the GenSGSStress only works with linear model. Is there anyone who have similar experience about that? Any suggestion is OK.
Xianbei
huangxianbei is offline   Reply With Quote
Old   November 20, 2014, 02:33
Huang Xianbei
After reading the source code, I think it's probably needed to modify the GenEddyVisc.C or GenSGSStress.C, the formula of devBeff,depending on which kind of model you want to solve. Because the solver will solve this part
Old   November 20, 2014, 07:52
Huang Xianbei
it's actually the right way to modify the GenEddyVisc into GennonlinearSGS, the problem remains is that how to add a new namespace into OpenFoam, as in LESModel.C, nuSgs is transferred to GenEddyVisc, so I should modify this file to something like LESModelnonlinear.
However, when I copied LESModel.C and LESModel.H into a new folder(also the make folder), it returns that no rule to create .dep
Old   November 20, 2014, 20:44
Huang Xianbei
Hi,all:
As nonlinear model is not compatible with the made-in code, I need to deal with the SGS stress instead of the eddy viscosity. So the nuSgs used in the conventional model should be replaced by a volTensorField representing the SGS stress.
However, in the namespace of LESModel, there are too many places where nuSgs is used, so I'd like to create a new namespace called LESNonlinearModel
However, when I compile, it returns that:
/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::incompressible::LESNonlinearModel::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)':
LESNonlinearModel.C:(.text+0x272): undefined reference to `Foam::incompressible::turbulenceModel::correct()'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::incompressible::LESNonlinearModel::LESNonlinearModel(Foam::word const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&)':
LESNonlinearModel.C:(.text+0x867): undefined reference to `Foam::incompressible::turbulenceModel::turbulenceModel(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&)'
LESNonlinearModel.C:(.text+0xba3): undefined reference to `Foam::LESdelta::New(Foam::word const&, Foam::fvMesh const&, Foam::dictionary const&)'
LESNonlinearModel.C:(.text+0xbf7): undefined reference to `Foam::surfaceInterpolation::deltaCoeffs() const'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::incompressible::turbulenceModel::type() const':
LESNonlinearModel.C:(.text._ZNK4Foam14incompressible15turbulenceModel4typeEv[Foam::incompressible::turbulenceModel::type() const]+0x3): undefined reference to `Foam::incompressible::turbulenceModel::typeName'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::fvPatchField<Foam::Tensor<double> >::type() const':
LESNonlinearModel.C:(.text._ZNK4Foam12fvPatchFieldINS_6TensorIdEEE4typeEv[Foam::fvPatchField<Foam::Tensor<double> >::type() const]+0x3): undefined reference to `Foam::fvPatchField<Foam::Tensor<double> >::typeName'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::type() const':
LESNonlinearModel.C:(.text._ZNK4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE4typeEv[Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::type() const]+0x3): undefined reference to `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::DimensionedField<Foam::Tensor<double>, Foam::volMesh>::type() const':
LESNonlinearModel.C:(.text._ZNK4Foam16DimensionedFieldINS_6TensorIdEENS_7volMeshEE4typeEv[Foam::DimensionedField<Foam::Tensor<double>, Foam::volMesh>::type() const]+0x3): undefined reference to `Foam::DimensionedField<Foam::Tensor<double>, Foam::volMesh>::typeName'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::incompressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::incompressible::LESNonlinearModel>::~addturbulenceModelConstructorToTable()':
LESNonlinearModel.C:(.text._ZN4Foam14incompressible15turbulenceModel36addturbulenceModelConstructorToTableINS0_17LESNonlinearModelEED2Ev[_ZN4Foam14incompressible15turbulenceModel36addturbulenceModelConstructorToTableINS0_17LESNonlinearModelEED5Ev]+0x1): undefined reference to `Foam::incompressible::turbulenceModel::destroyturbulenceModelConstructorTables()'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const':
LESNonlinearModel.C:(.text._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE[Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x122): undefined reference to `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
LESNonlinearModel.C:(.text._ZNK4Foam14objectRegistry12lookupObjectINS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEEEERKT_RKNS_4wordE[Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const]+0x1a5): undefined reference to `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::typeName'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::fv::gradScheme<Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)':
LESNonlinearModel.C:(.text._ZN4Foam2fv10gradSchemeINS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::gradScheme<Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x1d): undefined reference to `Foam::fv::debug'
LESNonlinearModel.C:(.text._ZN4Foam2fv10gradSchemeINS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::gradScheme<Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x3c): undefined reference to `Foam::fv::gradScheme<Foam::Vector<double> >::IstreamConstructorTablePtr_'
LESNonlinearModel.C:(.text._ZN4Foam2fv10gradSchemeINS_6VectorIdEEE3NewERKNS_6fvMeshERNS_7IstreamE[Foam::fv::gradScheme<Foam::Vector<double> >::New(Foam::fvMesh const&, Foam::Istream&)]+0x234): undefined reference to `Foam::fv::gradScheme<Foam::Vector<double> >::IstreamConstructorTablePtr_'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::DimensionedField<Foam::Tensor<double>, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField const&)':
LESNonlinearModel.C:(.text._ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC2ERKNS_16DimensionedFieldIS2_S4_EERKS6_[_ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC5ERKNS_16DimensionedFieldIS2_S4_EERKS6_]+0x3c): undefined reference to `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::debug'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&)':
LESNonlinearModel.C:(.text._ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEC2ERKS5_[_ZN4Foam14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEC5ERKS5_]+0xfe): undefined reference to `Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::debug'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)':
LESNonlinearModel.C:(.text._ZN4Foam3fvc4gradINS_6VectorIdEEEENS_3tmpINS_14GeometricFieldINS_12outerProductIS3_T_E4typeENS_12fvPatchFieldENS_7volMeshEEEEERKNS5_IS7_SA_SB_EE[Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)]+0xa5): undefined reference to `Foam::fvSchemes::gradScheme(Foam::word const&) const'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `Foam::fvPatchField<Foam::Tensor<double> >::snGrad() const':
LESNonlinearModel.C:(.text._ZNK4Foam12fvPatchFieldINS_6TensorIdEEE6snGradEv[Foam::fvPatchField<Foam::Tensor<double> >::snGrad() const]+0x17): undefined reference to `Foam::fvPatch::deltaCoeffs() const'
Make/linux64GccDPOpt/LESNonlinearModel.o: In function `_GLOBAL__sub_I_LESNonlinearModel.C':
LESNonlinearModel.C:(.text.startup+0xaf): undefined reference to `Foam::incompressible::turbulenceModel::constructturbulenceModelConstructorTables()'
LESNonlinearModel.C:(.text.startup+0xc7): undefined reference to `Foam::incompressible::turbulenceModel::turbulenceModelConstructorTablePtr_'
collect2: ld
Old   November 20, 2014, 23:49
Huang Xianbei
Problem solved
Here is the new class named LESNonlinearModel
LESNonlinear.tar.gz
Also, the GenEddyVisc is modified so that nuSgs here represents the SGS stress
The problem remains that how to apply this to the nonlinear model
Old   November 21, 2014, 04:35
Huang Xianbei
update again!
I have checked the above code and didn't found anything wrong. Also, it's successfully compiled into the source of openfoam-2.1.1.
So I go on with this~
In order to test it's ability in non-linear SGS stress modelling, I make a simple test
I modified the Smagorinsky model, make nuSgs = 2*nu()*(S+Omega)
S is the strain rate tensor and Omega is the rotation-rate tensor
Here is the test model
DNSM-forum.tar.gz
After this , I do a simple test using channel395 tutorial with the modified Smagorinsky model, however, error occurs as following
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting LES turbulence model DNSM
#0  Foam::error::printStack(Foam::Ostream&) in "/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::incompressible::LESNonlinearModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPOpt/lib/libLESNonlinearModels.so"
 in "/home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPOpt/bin/channelRotate"
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Does anyone knows how to solve it?
Xianbei
Old   November 21, 2014, 22:07
Huang Xianbei
As I read from here https://openfoamwiki.net/index.php/HowTo_debugging
sigSegV is caused by an application accessing memory outside the allocated space. These are nearly always caused by a programming error.However, I still can't figure out the problem.
The error appears at Foam::incompressible::LESNonlinearModel::New, however, this is a very common definition as a constructor
Old   November 23, 2014, 06:49
Default case run in debug mode, while crashes in opt mode,how?
Huang Xianbei
Hi,all:
I tried to implement a nonlinear SGS model into OF as here
http://www.cfd-online.com/Forums/ope...sgs-model.html
When I turn to the debug mode, the case runs normally, however, if I turn to Opt mode, it crashes with the following errors:
Reading field p
Reading field U
Selecting LES turbulence model Smagorinsky
Old   November 23, 2014, 07:19
Huang Xianbei
Another question is that the case can't be run in both modes,in Debug mode, it returns
huangxianbei@huangxianbei-MS-7673:/media/87771eb4-3e70-4aa9-b073-17fd62fd2c2a/huangxianbei/SM-non$ mpirunDebug -np 4 channelRotate -parallel
-np
channelRotate
-parallel
nProcs=4
exec=channelRotate
args="-parallel"
Constructed gdb initialization file /media/87771eb4-3e70-4aa9-b073-17fd62fd2c2a/huangxianbei/SM-non/gdbCommands
Choose running method: 0)normal  1)gdb+xterm  2)gdb  3)log  4)log+xterm  5)xterm+valgrind: 2
Run all processes local or distributed? 1)local  2)remote: 1
**sourceFoam:FOAM_INST_DIR=/home/huangxianbei/OpenFOAM . /home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc
    tail -f processor0.log
    tail -f processor1.log
    tail -f processor2.log
    tail -f processor3.log
Constructed /media/87771eb4-3e70-4aa9-b073-17fd62fd2c2a/huangxianbei/SM-non/mpirun.schema file.
    mpirun -app /media/87771eb4-3e70-4aa9-b073-17fd62fd2c2a/huangxianbei/SM-non/mpirun.schema </dev/null
Press return to execute.
Sorry!  You were supposed to get help about:
    find-available:not-valid
But I couldn't open the help file:
    /home/huangxianbei/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/share/openmpi/help-mca-base.txt: No such file or directory.  Sorry!
[huangxianbei-MS-7673:09097] *** Process received signal ***
[huangxianbei-MS-7673:09097] Signal: Segmentation fault (11)
[huangxianbei-MS-7673:09097] Signal code: Address not mapped (1)
[huangxianbei-MS-7673:09097] Failing at address: 0x28
[huangxianbei-MS-7673:09097] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7f6cc5deacb0]
[huangxianbei-MS-7673:09097] [ 1] /usr/lib/libopen-pal.so.0(mca_base_select+0x108) [0x7f6cc601a518]
[huangxianbei-MS-7673:09097] [ 2] /usr/lib/libopen-pal.so.0(opal_crs_base_select+0x7e) [0x7f6cc602c90e]
[huangxianbei-MS-7673:09097] [ 3] /usr/lib/libopen-pal.so.0(opal_cr_init+0x31e) [0x7f6cc600b0ee]
[huangxianbei-MS-7673:09097] [ 4] /usr/lib/libopen-pal.so.0(opal_init+0x159) [0x7f6cc600aa59]
[huangxianbei-MS-7673:09097] [ 5] /usr/lib/libopen-rte.so.0(orte_init+0x4d) [0x7f6cc625ca0d]
[huangxianbei-MS-7673:09097] [ 6] mpirun() [0x402fe5]
[huangxianbei-MS-7673:09097] [ 7] mpirun() [0x402b34]
[huangxianbei-MS-7673:09097] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f6cc5a3c76d]
[huangxianbei-MS-7673:09097] [ 9] mpirun() [0x402a59]
[huangxianbei-MS-7673:09097] *** End of error message ***
Old   November 23, 2014, 07:38
Huang Xianbei
I tried http://www.cfd-online.com/Forums/ope...tml#post417690
And fixed the above error in Debug mode
However, when run in parallel, the error appears the same as in Opt mode
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff62e3d5e in Foam::incompressible::LESNonlinearModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) ()
   from /home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPOpt/lib/libLESNonlinearModels.so
#0  0x00007ffff62e3d5e in Foam::incompressible::LESNonlinearModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) ()
#1  0x000000000044d5e0 in main (argc=2, argv=0x7fffffffced8)
    at createFields.H:43
(gdb) quit
A debugging session is active.
    Inferior 1 [process 21505] will be killed.
Quit anyway? (y or n) [answered Y; input not from terminal]
It's so strange that a case can be run in serial, but can't run in parallel!
Old   November 23, 2014, 15:53
Retired Super Moderator
Bruno Santos
Greetings Xianbei,
I'll be moving these posts to the other thread you've mentioned 3 posts ago, because the problem can only be diagnosed with the code provided there.
The problem is this piece of code:
DNSM::DNSM
    const volVectorField& U,
    const surfaceScalarField& phi,
    transportModel& transport,
    const word& turbulenceModelName,
    const word& modelName
    LESNonlinearModel(modelName, U, phi, transport, turbulenceModelName),
    GennonlinearSGS(U, phi, transport),
The last two lines are wrong, very-very wrong. You should only have the last one, namely:
DNSM::DNSM
otherwise, you've forcing a double construction of the derived class "LESNonlinearModel".
This is odd, because the compiler should have complained about this right away.
Best regards,
Bruno
Old   November 23, 2014, 20:04
Huang Xianbei
Originally Posted by wyldckat View Post
Greetings Xianbei,
DNSM::DNSM
DNSM::DNSM
Best regards,
Bruno
Hi,Bruno:
Thank you very much for your reply.
In the above package, I realize something could cause problem when I use a SymmTensor + Tensor
I make a modification and upload the following new code here
LESNonlinear-update.tar.gz
Also, I modified the Smagorinsky model
SM-non.tar.gz
There should be no problem in the mathematical expression then
I tried your method, however, the compiler complains that
Smagorinsky.C: In constructor 'Foam::incompressible::LESNonlinearModels::Smagorinsky::Smagorinsky(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&, const Foam::word&)':
Smagorinsky.C:74:5: error: no matching function for call to 'Foam::incompressible::LESNonlinearModel::LESNonlinearModel()'
Smagorinsky.C:74:5: note: candidates are:
/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LESNonlinear/lnInclude/LESModel.H:133:9: note: Foam::incompressible::LESNonlinearModel::LESNonlinearModel(const Foam::word&, const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&)
/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LESNonlinear/lnInclude/LESModel.H:133:9: note:   candidate expects 5 arguments, 0 provided
/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LESNonlinear/lnInclude/LESModel.H:101:9: note: Foam::incompressible::LESNonlinearModel::LESNonlinearModel(const Foam::incompressible::LESNonlinearModel&)
/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/LESNonlinear/lnInclude/LESModel.H:101:9: note:   candidate expects 1 argument, 0 provided
make: *** [Make/linux64GccDPDebug/Smagorinsky.o] Error 1
It can be compiled only if
is kept.
Also, in the original source in Smagorinsky.C
    LESModel(modelName, U, phi, transport, turbulenceModelName),
    GenEddyVisc(U, phi, transport),
I'm confused about the problem
I recompiled the whole code in Opt mode and then run the case in Debug mode in parallel using
mpirun -np 4 channelFoam -parallel
it goes well.
However, it's still a problem that the case crashes in Opt mode with the same error returns in the former post, or if we run the case like this:
mpirunDebug -np 4 channelFoam -parallel
The error remains because the program will load libso from Opt instead of Debug as following
[0] #0  Foam::error::printStack(Foam::Ostream&) in "/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigSegv::sigHandler(int) in "/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  Foam::incompressible::LESNonlinearModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPOpt/lib/libLESNonlinearModels.so"
[0] #4
[0]  at ~/OpenFOAM/huangxianbei-2.1.1/applications/channelRotate/createFields.H:56
[0] #5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #6
[0]  in "/home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPDebug/bin/channelRotate"
[huangxianbei-MS-7673:18884] *** Process received signal ***
[huangxianbei-MS-7673:18884] Signal: Segmentation fault (11)
[huangxianbei-MS-7673:18884] Signal code:  (-6)
[huangxianbei-MS-7673:18884] Failing at address: 0x3e8000049c4
[huangxianbei-MS-7673:18884] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff111a604a0]
[huangxianbei-MS-7673:18884] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7ff111a60425]
[huangxianbei-MS-7673:18884] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff111a604a0]
[huangxianbei-MS-7673:18884] [ 3] /home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPOpt/lib/libLESNonlinearModels.so(_ZN4Foam14incompressible17LESNonlinearModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelERKNS_4wordE+0x18e) [0x7ff112f5bd5e]
[huangxianbei-MS-7673:18884] [ 4] /home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPDebug/bin/channelRotate() [0x44d5e0]
[huangxianbei-MS-7673:18884] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7ff111a4b76d]
[huangxianbei-MS-7673:18884] [ 6] /home/huangxianbei/OpenFOAM/huangxianbei-2.1.1/platforms/linux64GccDPDebug/bin/channelRotate() [0x44cbe9]
[huangxianbei-MS-7673:18884] *** End of error message ***
It's really quite strange
Old   January 2, 2015, 09:48
Bruno Santos
Hi Xianbei,
I've finally managed to look into this. Here's what I've found:
  1. The file "LESNonlinear/Make/files" was incorrectly configured, since it should be something like this:
    LIB = $(FOAM_USER_LIBBIN)/libLESNonlinearModels
  2. In "LESNonlinear/Make/options" you had this:
    -I/home/huangxianbei/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/LES/LESdeltas/lnInclude
    When it should be this:
    -I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude
  3. And the rest is related to how things are organized.
This one was very tricky... I had a hard time getting this to work properly. The main problem is that the pointer "dictionaryConstructorTablePtr_" was empty when the constructor tried to get things working.
I've attached the tarball "nonlinearLESkit-v1.tar.gz" that has the working folder structure I built based on your files, in addition to adding more of the necessary files and example case. Note: This is meant to be used with OpenFOAM 2.1.1.
To use:
  1. Unpack:
    tar -xf nonlinearLESkit-v1.tar.gz
  2. Build:
    cd nonlinearLESkit
    ./Allwmake
  3. The test case:
    cd exampleCaseChannel395/
    ./Allrun
    Note: this last command will also copy the "0" folder from the original tutorial "incompressible/channelFoam/channel395", since it's about 1MB of initial boundary conditions that the tutorial already has.
The modified solver is not yet working, since "nuSgs" is different from the original model.
Oh, the missing important detail is that this line:
    constructdictionaryConstructorTables();
It was missing from the "LESNonlinearModel::New" method... although I haven't figured out why "LESModel" doesn't need this hack... I'll dig deeper and edit this post to report back if I can figure it out.
edit: OK, I've figured it out. When optimized, there are some-things that aren't called because it's non-optimal to call something that isn't going to be used in the first place. This might not be the exact situation in this case, but it's probably very close to the truth.
So, if the example simulation case has this entry in the "controlDict" file:
libs
  "libSmagorinsky.so"
it will enforce that the table is constructed in order to add the very first new model. If no models were added, then the table would not be constructed in the first place. This pretty much happens in the file "Smagorinsky.C", in this line:
addToRunTimeSelectionTable(LESNonlinearModel, Smagorinsky, dictionary);
which will construct said table for the first time.
Best regards,
Bruno
Last edited by wyldckat; February 8, 2015 at 08:28. Reason: see "edit:" and "Note:"
Old   January 6, 2015, 06:08
Huang Xianbei
Hi Xianbei,
libs
  "libSmagorinsky.so"
Best regards,
Bruno
Hi, Bruno:
Thank you very much for the details. You mean that
libs
  "libSmagorinsky.so"
This part of code should be added to the controlDict, right?
I will try it latter.
Xianbei
Old   January 10, 2015, 09:40
Bruno Santos
Hi Xianbei,
Originally Posted by huangxianbei View Post
You mean that
libs
  "libSmagorinsky.so"
Yes, that's correct. But make sure you do not have two different blocks, like this:
libs
  "libSmagorinsky.so"
libs
  "libOpenFOAM.so"
because this will mean that only one of them will be loaded. If you need more than one, then it would be something like this:
libs
  "libSmagorinsky.so"
  "libOpenFOAM.so"
Best regards,
Bruno
Old   January 10, 2015, 23:02
Huang Xianbei
Hi Xianbei,
libs
  "libSmagorinsky.so"
libs
  "libOpenFOAM.so"
libs
  "libSmagorinsky.so"
  "libOpenFOAM.so"
Best regards,
Bruno
Oh,I see, the order is important, if not, the built-in Smagorinsky is loaded!
Old   January 11, 2015, 12:38
Bruno Santos
Quick answer: It's not a question of order. The problem is really that two occurrences of "libs" will result in failure to load the other libraries, because the parser will not care about them.
Old   January 11, 2015, 20:40
Huang Xianbei
Thank you,Bruno. But I'm confused about the libs, as here http://www.cfd-online.com/Forums/ope...agorinsky.html
The testcase provided is used as
libs ( "libOpenFOAM.so" "libdynamicSmagorinskyModel.so" ) ;
This will not cause problem. So when will the problem occur?
Old   January 18, 2015, 15:07
Bruno Santos
Quick answer - the error might happen if you do the following by accident:
libs ( "libOpenFOAM.so" );
libs ( "libdynamicSmagorinskyModel.so" );
And the only problem is that not all of the listed libraries will be loaded, because only the first entry of "libs" will work.
Old   February 3, 2015, 18:30
karar
zoptirik is on a distinguished road
Hi
Did you solve your problem. because I
also, deal with the SGS stress instead of the eddy viscosity. i have try to compiled yours nonlinearLEskit. but it gave me compalition error (error 1)
zoptirik is offline   Reply With Quote
Two way Fsi Problem- Non linear problem kmgraju CFX 4 April 28, 2015 11:15
the combustion model problem hanshandiaoke STAR-CD 7 December 2, 2011 03:47
the combustion model problem hanshandiaoke Siemens 0 November 25, 2011 20:37
Problem in Buoyancy Model? dhrubo CFX 3 June 5, 2010 05:32
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
