magnetostaticFoam / how to set correct boundary conditions for every cell..? |
July 16, 2015, 09:23 |
Jan
Rep Power: 11 |
Hey there,
I'm trying to use a solver for magnetostatic fields (with areas of different permeability) … I thought that shouldn't be a problem for openFoam and started very enthusiastic … I did quite some reading lately … but am a little bit frustrated right now … … i ran some tutorials, programmed the rodfoam-solver (http://www.tfd.chalmers.se/~hani/kurser/OS_CFD – works perfectly) and then programmed this (http://webfiles.portal.chalmers.se/e...heHuangMSc.pdf) solver that should have been perfect for my purposes. First I was a little bit irritated I wasn't able to find it ready-to-use in the openfoam-package … but now I'm pretty sure it is because it simply doesn't work properly … At first it seems like an easy task to set up a magnetostatic solver … just Code:
solve ( 1.0/(muMag*muR)*fvm::laplacian(A)==-J; In my mind at least these boundary conditions (on every cell face) have to be implemented … (the mhdFoam-solver doesn't use a magnetic vector potential and ignores these boundary conditions in the same way the other solvers do … i already looked how it was done there) How can I get access to „neighbour-variables“ within a solver …? I found http://www.cfd-online.com/Forums/ope...vsf1-vsf2.html but am not sure if it really is what I need and if i can use these commands in any solver or if I would have to change the source of OpenFoam itself … and to be honest … I have some problems with the solver algorithms … why is the output of Code:
solve ( fvm::laplacian(viR,A)==-J*muMag ); Code:
solve ( fvm::laplacian(A)==-J*muMag/viR ); This has something to do with local variable values of different cells …? I'm a little bit lost … and I don't really see where to start right now … I would like to set somewhere the relations B_tan2 = B_tan1*muR_2/muR_1 and B_normal == const. And then have my div(B) == 0 and rot(H)=J solved :-O … Could you please help me to get started with this task ..? I'm looking forward for hints how to get this solver running! Last edited by riddim; July 16, 2015 at 11:08. |
July 14, 2019, 11:25 |
magnetostatic in openfoam
Saleh Abuhanieh
Rep Power: 8 |
I wonder if anybody figure out how to solve a magnetostatic model using openfoam. Regards, Saleh |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
