February 18, 2016, 14:39 |
Funny behavior of twoPhaseEulerFoam
Bo Kong
Rep Power: 16 |
I was investigating the mass conversation problem of implicitly solving particle volume fraction due to stiff particle pressure. And I built a case of a vertical periodic channel for twoPhaseEulerFoam with fixed gas flow rate. I made the volume fraction not uniform, with higher particle volume fraction on the top. The three following pictures are the initial condition, after 2 seconds and after 5 seconds. I used foam 24x here, instead of 30x due to the change of the pressure definition. And as you can see, I decomposed the domain to 4 processors.
init.jpg 2sec.jpg 5sec.jpg Here is the case file, with the body force fvoption to keep gas flow rate constant. verticalChannel_1.tar.gz This is probably caused by the inconsistency of pphiPp on the processor boundary. What is truly significant is that in this 5 seconds, the amount of particles increased 2%, which is a lot. That is due to the Laplace term in alpha equation, but even scheme was changed to "corrected", the mass still increases, which is a big problem for my current homogenous DNS simulations using my own solvers. If anybody has a good idea on how to fix it, I will be very grateful. Last edited by bokong; February 18, 2016 at 16:07. |
February 19, 2016, 04:37 |
anonymous
Rep Power: 12 |
If you consider this problem as a bug, you might want to report it on the OpenFOAM's mantis bug platform.
Do you have the same problem in serial? If I remember correctly there were important changes for twoPhaseEulerFoam from 2.4.x to 3.0.x |
residuals for velocity - twoPhaseEulerFoam | avila.vc | OpenFOAM Running, Solving & CFD | 1 | May 27, 2019 07:37 |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 17:45 |
twoPhaseEulerFoam and complex geometry | bsoubelet | OpenFOAM Running, Solving & CFD | 7 | July 2, 2015 10:50 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 08:10 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 16:24 |
