Funny behavior of twoPhaseEulerFoam
Old   February 18, 2016, 14:39
Default Funny behavior of twoPhaseEulerFoam
Bo Kong
bokong is on a distinguished road
I was investigating the mass conversation problem of implicitly solving particle volume fraction due to stiff particle pressure. And I built a case of a vertical periodic channel for twoPhaseEulerFoam with fixed gas flow rate. I made the volume fraction not uniform, with higher particle volume fraction on the top. The three following pictures are the initial condition, after 2 seconds and after 5 seconds. I used foam 24x here, instead of 30x due to the change of the pressure definition. And as you can see, I decomposed the domain to 4 processors.
Here is the case file, with the body force fvoption to keep gas flow rate constant.
verticalChannel_1.tar.gz
This is probably caused by the inconsistency of pphiPp on the processor boundary.
What is truly significant is that in this 5 seconds, the amount of particles increased 2%, which is a lot. That is due to the Laplace term in alpha equation, but even scheme was changed to "corrected", the mass still increases, which is a big problem for my current homogenous DNS simulations using my own solvers. If anybody has a good idea on how to fix it, I will be very grateful.
bokong is offline   Reply With Quote
Old   February 19, 2016, 04:37
anonymous
ssss is on a distinguished road
If you consider this problem as a bug, you might want to report it on the OpenFOAM's mantis bug platform.
Do you have the same problem in serial?
If I remember correctly there were important changes for twoPhaseEulerFoam from 2.4.x to 3.0.x
ssss is offline   Reply With Quote
residuals for velocity - twoPhaseEulerFoam avila.vc OpenFOAM Running, Solving & CFD 1 May 27, 2019 07:37
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 17:45
twoPhaseEulerFoam and complex geometry bsoubelet OpenFOAM Running, Solving & CFD 7 July 2, 2015 10:50
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? ThomasV OpenFOAM 0 November 11, 2013 08:10
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 16:24
