Write a new application for parallel execution
Old   September 11, 2017, 21:34
Default Write a new application for parallel execution
dario
dariodario32 is on a distinguished road
Hi all,
I'm working on a new solver for FSI applications. I would like to know if there are some guidelines to code a new application in parallel. In particular some of the fields that I declare belong to a different mesh (the mesh of the structure), thought I don't know how they are manipulated in parallel processing.
Moreover in the code I use a system call, through system("name of external fem solver").
I want to call this command in serial even when I'm running the entire code in parallel. Is there any trick to do that?
Thanks,
Dario
dariodario32 is offline   Reply With Quote
Error in compute process - No Active Application yetlyg FLUENT 8 October 27, 2018 22:30
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 11:52
[snappyHexMesh] Debug option in snappy / Write volScalarField with cellLevel for postprocessing Ruli OpenFOAM Meshing & Mesh Conversion 1 March 30, 2014 08:57
Can Anyone help me to write a momentum source udf ? Ozora Fluent UDF and Scheme Programming 0 December 11, 2013 03:44
UDF to write interp files Karl FLUENT 6 February 7, 2002 12:10
