[New solver] buoyantPorousSimpleFoam implicit porous |
September 13, 2016, 12:20 |
Huynh Phong Thanh
Rep Power: 12 |
Hi everyone,
I made a solver "buoyantPorousSimpleFoam" based on buoyantSimpleFoam OF 2.2.x. I know that buoyantSimpleFoam original can run porous with explicit. But I want to simulate with implicit option, it will easier to reach convergence and faster than explicit option. What I did: In order to write buoyantPorousSimpleFoam, I review code of rhoPorousSimpleFoam and porousInterFoam. porousInterFoam solves p_rgh as the buoyantSimpleFoam but it is only explicit porous. So I prefer rhoPorousSimpleFoam to make code for buoyantPorousSimpleFoam. My problem I ran a test case in rhoPorousSimpleFoam and buoyantPorousSimpleFoam which gravity equal zero but the pressure loss both of solvers are difference. Does someone can give me a hint how to set these files right? Here is the content of code: buoyantPorousSimpleFoam.C Code:
#include "fvCFD.H" #include "rhoThermo.H" #include "RASModel.H" #include "radiationModel.H" #include "simpleControl.H" #include "fvIOoptionList.H" #include "IOporosityModelList.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" simpleControl simple(mesh); #include "readGravitationalAcceleration.H" #include "createFields.H" #include "createFvOptions.H" #include "createRadiationModel.H" #include "createZones.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (simple.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; // Pressure-velocity SIMPLE corrector { #include "UEqn.H" #include "EEqn.H" #include "pEqn.H" } turbulence->correct(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************************************* // Code:
IOporosityModelList pZones(mesh); Switch pressureImplicitPorosity(false); // nUCorrectors used for pressureImplicitPorosity int nUCorr = 0; if (pZones.active()) { // nUCorrectors for pressureImplicitPorosity simple.dict().readIfPresent("nUCorrectors", nUCorr); if (nUCorr > 0) { pressureImplicitPorosity = true; Info<< "Using pressure implicit porosity" << endl; } else { Info<< "Using pressure explicit porosity" << endl; } } Code:
{ rho = thermo.rho(); rho.relax(); volScalarField rAU(1.0/UEqn().A()); surfaceScalarField rhorAUf("Dp", fvc::interpolate(rho*rAU)); volVectorField HbyA("HbyA", U); if (pressureImplicitPorosity) { HbyA = trTU() & UEqn().H(); } else { HbyA = trAU()*UEqn().H(); } UEqn.clear(); surfaceScalarField phig(-rhorAUf*ghf*fvc::snGrad(rho)*mesh.magSf()); surfaceScalarField phiHbyA ( "phiHbyA", fvc::interpolate(rho)*(fvc::interpolate(HbyA) & mesh.Sf()) ); fvOptions.relativeFlux(fvc::interpolate(rho), phiHbyA); bool closedVolume = adjustPhi(phiHbyA, U, p_rgh); phiHbyA += phig; while (simple.correctNonOrthogonal()) { tmp<fvScalarMatrix> tpEqn; if (pressureImplicitPorosity) { tpEqn = (fvm::laplacian(rho*trTU(), p_rgh) == fvc::div(phiHbyA)); } else { tpEqn = (fvm::laplacian(rho*trAU(), p_rgh) == fvc::div(phiHbyA)); }; tpEqn().setReference(pRefCell, getRefCellValue(p_rgh, pRefCell)); tpEqn().solve(); if (simple.finalNonOrthogonalIter()) { // Calculate the conservative fluxes phi = phiHbyA - tpEqn().flux(); // Explicitly relax pressure for momentum corrector p_rgh.relax(); // Correct the momentum source with the pressure gradient flux // calculated from the relaxed pressure if (pressureImplicitPorosity) { U = HbyA + (trTU() & fvc::reconstruct((phig - tpEqn().flux())/rhorAUf)); } else { U = HbyA + (trAU()*fvc::reconstruct((phig - tpEqn().flux())/rhorAUf)); } U.correctBoundaryConditions(); fvOptions.correct(U); } } #include "continuityErrs.H" p = p_rgh + rho*gh; // For closed-volume cases adjust the pressure level // to obey overall mass continuity if (closedVolume) { p += (initialMass - fvc::domainIntegrate(psi*p)) /fvc::domainIntegrate(psi); p_rgh = p - rho*gh; } rho = thermo.rho(); rho.relax(); Info<< "rho max/min : " << max(rho).value() << " " << min(rho).value() << endl; } Code:
// Solve the Momentum equation tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevRhoReff(U) == fvOptions(rho, U) ); UEqn().relax(); tmp<volScalarField> trAU; tmp<volTensorField> trTU; // fvOptions.constrain(UEqn()); if (pressureImplicitPorosity) { tmp<volTensorField> tTU = tensor(I)*UEqn().A(); pZones.addResistance(UEqn(), tTU()); trTU = inv(tTU()); trTU().rename("rAU"); fvOptions.constrain(UEqn()); volVectorField gradp(fvc::reconstruct((ghf*fvc::snGrad(rho) + fvc::snGrad(p_rgh))*mesh.magSf())); for (int UCorr=0; UCorr<nUCorr; UCorr++) { U = trTU() & (UEqn().H() - gradp); } U.correctBoundaryConditions(); fvOptions.correct(U); } else { pZones.addResistance(UEqn()); fvOptions.constrain(UEqn()); // solve(UEqn() == -fvc::grad(p)); // fvOptions.correct(U); if (simple.momentumPredictor()) { solve ( UEqn() == fvc::reconstruct ( ( - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) )*mesh.magSf() ) ); fvOptions.correct(U); } trAU = 1.0/UEqn().A(); trAU().rename("rAU"); } https://1drv.ms/u/s!AkLk2AeMilR1g517bxSoT0IHNg7BQA Any suggestions would be appreciated. Thanh Last edited by hiuluom; September 13, 2016 at 21:40. |
September 18, 2016, 10:52 |
Huynh Phong Thanh
Rep Power: 12 |
Hi all,
If I only add resistance in momentum equation, the pressure loss equivalent to rhoPorousSimpleFoam. Code:
// Solve the Momentum equation tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevRhoReff(U) == fvOptions(rho, U) ); UEqn().relax(); pZones.addResistance(UEqn()); fvOptions.constrain(UEqn()); if (simple.momentumPredictor()) { solve ( UEqn() == fvc::reconstruct ( ( - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) )*mesh.magSf() ) ); fvOptions.correct(U); } Code:
porous { type DarcyForchheimer; active yes; cellZone porous; DarcyForchheimerCoeffs { d d [ 0 -2 0 0 0 0 0 ] ( 0 0 0 ); f f [ 0 -1 0 0 0 0 0 ] ( 289.7 -1000 -1000); coordinateSystem { e1 ( 0 0 -1 ); e2 ( 0 1 0 ); } } } If I try my sample case as porous parameter above with rhoPorousSimpleFoam in explicit option that means nUCorrectors = 0, the pressure loss have been never reached convergence at least the mesh at porous zone must be finest. Best, Thanh |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Modelling sound propagation through layered porous media | nkinar | Main CFD Forum | 0 | July 4, 2010 14:45 |
species mass source in porous media ? | PK | FLUENT | 0 | February 16, 2007 11:12 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
