Forcing the value of a point in internal Domain to remain fixed.
Old   April 16, 2017, 03:10
Default Forcing the value of a point in internal Domain to remain fixed.
Mehdi Aminyavari
Mehdi3031 is on a distinguished road
Hello dear Foamers,
I am developing a twophase flow solver where I solve species balance (binary mixture) for both phases; YlEqn and YgEqn.
Lets take the YgEqn as an example:
    fvScalarMatrix YgEqn
        fvm::ddt(alpha2*rho2, yg)
      + fvm::div(rho2Phialpha2, yg, "div(rhoPhiAlpha,yg)")
      - fvm::laplacian(alpha2*rho2*Dg, yg)
    ygEqn.relax();
    ygEqn.solve();
Now if you look at the picture that I attached, there is a line called interface which I can know it's location inside the domain with Alpha (volume fraction).
what I want to do now is to force yg to be equal to ygi (which I calculate from an external function) on the interface. so basically it is like a fixed value boundary condition, but inside the domain and not on the boundary.
the good point is that I know where inside the domain and which cell, but I am not sure how I should force it's value to remain constant and not be affected by the other cells.
Any hint would be really appreciated.
Mehdi3031 is offline   Reply With Quote
Old   April 16, 2017, 07:13
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Possibly, ExplicitSetValue is what you need.
    fvOptions(rho, yg)
fvOptions.constrain(YgEqn);
ygEqn.relax();
ygEqn.solve();
Then add fvOptions file with an entry of type ExplicitSetValue to your case (search on the forum to learn how to use it and ask here if need more info).
Zeppo is offline   Reply With Quote
Old   April 17, 2017, 05:09
Mehdi Aminyavari
    fvOptions(rho, yg)
ygEqn.relax();
ygEqn.solve();
hello Zeppo,
Thank you so much for your reply, I actually thought of that at the beginning, but the point is that these values of Ygi are a function of P and T and I solve also energy equation and these values should get updated on runtime after energy equation is solved in each timestep.
Yg[celli]=Function_Ygi(T[celli],p[celli])
where celli is the index of the cells where there is interface.
So I need to force the values of Yg to be Ygi from the solver.
Can you think of any way to revise the YgEgn in the solver to do that?
Once again I really appreciate your help.
Happy Easter
Old   April 18, 2017, 13:42
Default How about this?
Mehdi Aminyavari
I figured out something but I am not sure if it is correct or not, I read on another post that this should work like this by using "setValues":
   fvScalarMatrix ygEqn
forAll(alpha2,celli){
				if ( alpha2[celli] != 0 && alpha2[celli] != 1)
					label ref = celli;
					labelList refCells (1,ref);
					scalarField refValues (1, ygi[celli]);
					ygEqn.setValues(refCells, refValues);
    ygEqn.relax();
    ygEqn.solve();
but when I do this and I print the values of yg and ygi of the interface cells as following, they are not equal.
Any idea what am I doing wrong?
					Info << "  alpha2 = " << alpha2[celli]
					<< "  yg = " << yg[celli]
					<< "  =? ygi = " << ygi[celli]
					<< endl;
Old   April 21, 2017, 15:23
Zeppo's Avatar
Sergei
What is the code between the snippets from your latest post? ygi might somehow be modified there or something?
Old   April 22, 2017, 09:45
Mehdi Aminyavari
Dear Zeppo, Thank you for your reply, Actually the problem was with a source term that I had on the same cell, When I cancelled the source term, setValue was working perfectly.
Thank you so much
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 10:38
Named selection for internal surfaces in the domain Ahmed Saeed CFX 1 November 20, 2013 09:32
