August 31, 2017, 06:54 |
Source to drive velocity to zero
Philippose Rajan
Rep Power: 25 |
Hello everybody,
A Good day to you all. I have a quick question which I have been breaking my head over for a while now. I need to simulate a case where depending on the flow through a patch, I need to increase or decrease the flow resistance at another location within the mesh, something like a variable orifice. My intention is to do this without mesh morphing or topological changes, but rather, to use something like an "alpha" field to somehow drive the velocity at the right locations in the mesh to zero to emulate a blockage. As of now, I have included the following source term into the Ueqn of a modified simpleFoam solver...: Code:
tmp<fvVectorMatrix> tUEqn ( fvm::div(phi, U) + MRF.DDt(U) + turbulence->divDevReff(U) + fvm::Sp(alpha*max(mag(U)).value(), U) == fvOptions(U) ); The part: Code:
max(mag(U)).value() The code seems to be working, but I dont see the velocity being driven down to zero.... it creates a kind of blockage, but I have had cases where even though the entire channel is blocked (alpha = 1000), I still have flow through, though, lesser than if there was no block. However, my intention is to drive the velocity in all the cells where the alpha field is 1000 to zero. Could someone please help me out? Thank you. Wish you a good afternoon ahead. Regards, Philippose |
September 1, 2017, 04:53 |
Philippose Rajan
Rep Power: 25 |
Hello again,
A Good Friday Morning to everyone :-) So, I have basically solved the problem I had with injecting a source into the simulation to drive the velocity to zero at various locations. It was a conceptual oversight on my part. It would be too involved to explain it here without going into the brackground, which would make this post too long and boring. If anyone is interested, you can let me know, and I can try to explain the problem, and the potential solution. Wish you all a good weekend ahead. Regards, Philippose |
October 28, 2017, 12:17 |
Kristjan
Rep Power: 9 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
