Adding side force to forceCoeffs.C
Like Tree3Likes
Old   September 28, 2011, 08:53
Default Adding side force to forceCoeffs.C
Daniel
drrbradford is on a distinguished road
I have edited forceCoeffs.C to include side forces by basically copying the dragDig, dragForce etc entries and adding an additional line with sfDir and sideForce. When I have recompiled forceCoeffs and added a sfDir option to my controlDict it gives no output for lift, drag nor side force.
An example of how I have edited the forceCoeffs.C:
        scalar liftForce = totForce & liftDir_;
        scalar dragForce = totForce & dragDir_;
        scalar sideForce = totForce & sfDir_;
        scalar pitchMoment = totMoment & pitchAxis_;
        scalar Cl = liftForce/(Aref_*pDyn);
        scalar Cd = dragForce/(Aref_*pDyn);
        scalar Cy = sideForce/(Aref_*pDyn);
        scalar Cm = pitchMoment/(Aref_*lRef_*pDyn);
forceCoeffs works based on the totForce value so I don't need to edit the forces function, right? I take it I need to make some changes in the included .H files but I can't see any references to lift or drag except in forceCoeffs.C.
Any help is appreciated,
Daniel.
rafiee.ad likes this.
drrbradford is offline   Reply With Quote
Old   September 28, 2011, 10:24
Daniel
I made a typo in the .C file which I have corrected and now it works. Sorry about that.
For anyone interested, the new forceCoeffs.C is below and all you have to do is add a sfDir specification in the functions subdict of the controlDict file.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2004-2010 OpenCFD Ltd.
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "forceCoeffs.H"
#include "dictionary.H"
#include "Time.H"
#include "Pstream.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
defineTypeNameAndDebug(Foam::forceCoeffs, 0);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::forceCoeffs::forceCoeffs
    const word& name,
    const objectRegistry& obr,
    const dictionary& dict,
    const bool loadFromFiles
    forces(name, obr, dict, loadFromFiles),
    liftDir_(vector::zero),
    dragDir_(vector::zero),
    sfDir_(vector::zero),
    pitchAxis_(vector::zero),
    magUInf_(0.0),
    lRef_(0.0),
    Aref_(0.0)
    read(dict);
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::forceCoeffs::~forceCoeffs()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::forceCoeffs::read(const dictionary& dict)
    if (active_)
        forces::read(dict);
        // Directions for lift and drag forces, and pitch moment
        dict.lookup("liftDir") >> liftDir_;
        dict.lookup("dragDir") >> dragDir_;
        dict.lookup("sfDir") >> sfDir_;
        dict.lookup("pitchAxis") >> pitchAxis_;
        // Free stream velocity magnitude
        dict.lookup("magUInf") >> magUInf_;
        // Reference length and area scales
        dict.lookup("lRef") >> lRef_;
        dict.lookup("Aref") >> Aref_;
void Foam::forceCoeffs::writeFileHeader()
    if (forcesFilePtr_.valid())
        forcesFilePtr_()
            << "# Time" << tab << "Cd" << tab << "Cl" << tab << "Cy" << tab << "Cm" << endl;
void Foam::forceCoeffs::execute()
    // Do nothing - only valid on write
void Foam::forceCoeffs::end()
void Foam::forceCoeffs::write()
    if (active_)
        // Create the forces file if not already created
        makeFile();
        forcesMoments fm = forces::calcForcesMoment();
        scalar pDyn = 0.5*rhoRef_*magUInf_*magUInf_;
        vector totForce = fm.first().first() + fm.first().second();
        vector totMoment = fm.second().first() + fm.second().second();
        if (Pstream::master())
            forcesFilePtr_()
                << obr_.time().value() << tab
                << Cd << tab << Cl << tab << Cy << tab << Cm << endl;
            if (log_)
                Info<< "forceCoeffs output:" << nl
                    << "    Cd = " << Cd << nl
                    << "    Cl = " << Cl << nl
                    << "    Cy = " << Cy << nl
                    << "    Cm = " << Cm << nl
                    << endl;
Old   October 29, 2012, 02:12
Rider is on a distinguished road
Hi all,
I'm interested by the new forceCoeffs.C file.
I try to test it but it don't works.
I updated the forceCoeffs.C, then I added sfDir line in the forceCoeffs file. Finally, I recompile OpenFOAM. What is wrong with the method?
Thanks for your explanation
Rider is offline   Reply With Quote
Old   October 30, 2012, 03:21
No suggestion ?
Old   November 4, 2012, 05:49
Retired Super Moderator
Bruno Santos
Hi Rider,
Attached is the adapted code based on drrbradford's modifications. The main difference is only how the modifications were made:
  1. I first made a copy of the library "$FOAM_SRC/postProcessing/functionObjects/forces" onto my personal user folder:
    cd $FOAM_RUN
    cd ..
    cp -r $FOAM_SRC/postProcessing/functionObjects/forces forceDirCoeffs
  2. Removed the excess folders in this new folder "forceDirCoeffs" and renamed "forceCoeffs" folder inside it, leaving this way only two folders:
    forceDirCoeffs
    Make
  3. Edited "Make/files" and this is what's inside it now:
    forceDirCoeffs/forceDirCoeffs.C
    forceDirCoeffs/forceDirCoeffsFunctionObject.C
    LIB = $(FOAM_USER_LIBBIN)/libforceDirCoeffs
  4. Edited "Make/options" and made it depend/include the original function object library, since there are things we need from it (I think...):
    EXE_INC = \
        -I$(LIB_SRC)/finiteVolume/lnInclude \
        -I$(LIB_SRC)/meshTools/lnInclude \
        -I$(LIB_SRC)/sampling/lnInclude \
        -I$(LIB_SRC)/transportModels \
        -I$(LIB_SRC)/turbulenceModels \
        -I$(LIB_SRC)/turbulenceModels/LES/LESdeltas/lnInclude \
        -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
        -I$(LIB_SRC)/postProcessing/functionObjects/forces/lnInclude
    LIB_LIBS = \
        -lincompressibleTransportModels \
        -lincompressibleRASModels \
        -lincompressibleLESModels \
        -lbasicThermophysicalModels \
        -lspecie \
        -lcompressibleRASModels \
        -lcompressibleLESModels \
        -lfiniteVolume \
        -lmeshTools \
        -lsampling \
        -lforces
  5. Renamed all files inside the sub-folder "forceDirCoeffs", adding "Dir" after "force".
  6. Edited all of the renamed files and did the same search and replace of "forceCoeffs" to "forceDirCoeffs".
  7. Finally added the modifications described in the first two posts.
To build it:
wmake libso
To use it:
  1. Instead of referring to the library "libforces.so", you now refer to "libforceDirCoeffs.so".
  2. Instead of "forceCoeffs" in the case's "controlDict" file, you now use "forceDirCoeffs". Keep in mind that you now also have a vector entry named "sfDir".
I haven't tested this, so I can only assume that it works
Best regards,
Bruno
Old   November 5, 2012, 03:48
Thank you for this work and your time.
When I used "wmake" or "sudo bash ./Allmake" in the directory "functionObjects", I had this error message "wmake : command not found"
What is the problem ?
Thanks all.
Old   November 5, 2012, 03:54
Bruno Santos
Hi Rider,
Unpack the package in a user folder of yours, not in OpenFOAM's source code folder!
And use:
wmake libso
for building the contents of the previously attached package!
To get a better understanding of what I'm talking/writing about, perhaps you should study a bit this tutorial: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Best regards,
Bruno
Old   November 5, 2012, 05:19
Hi Bruno,
I had misunderstood the structure of the modification ... It works.
I will test it now
Thanks a lot !
Old   September 30, 2013, 06:22
Exclamation Error in compiling utility
Himanshu Sharma
himanshu28 is on a distinguished road
Originally Posted by wyldckat View Post
Hi Rider,
    cd $FOAM_RUN
    cd ..
    forceDirCoeffs
    Make
    EXE_INC = \
    LIB_LIBS = \
        -lspecie \
        -lfiniteVolume \
        -lmeshTools \
        -lsampling \
        -lforces
To build it:
wmake libso
To use it:
Best regards,
Bruno
Hi Bruno ,
First off all thanks for the utility, But i am not able to build it properly on my system i am following quoted steps you have provided but its giving me some error. given below.
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file forceDirCoeffs/forceDirCoeffs.C
could not open file writer.H for source file forceDirCoeffs/forceDirCoeffs.C
Making dependency list for source file forceDirCoeffs/forceDirCoeffsFunctionObject.C
could not open file writer.H for source file forceDirCoeffs/forceDirCoeffsFunctionObject.C
SOURCE=forceDirCoeffs/forceDirCoeffs.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/sampling/lnInclude -I/opt/openfoam221/src/transportModels -I/opt/openfoam221/src/turbulenceModels -I/opt/openfoam221/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/postProcessing/functionObjects/forces/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/forceDirCoeffs.o
In file included from forceDirCoeffs/forceDirCoeffs.H:40:0,
                 from forceDirCoeffs/forceDirCoeffs.C:26:
/opt/openfoam221/src/postProcessing/functionObjects/forces/lnInclude/forces.H:115:20: fatal error: writer.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/forceDirCoeffs.o] Error 1
Since i am new to OpenFoam please help me with that. i tried to locate the writer.H and found it in "src/fileFormate/lnInclude" i tried to copy that to the lnInclude provided inside your provide utility. so the error posted above was removed but. a new error came posted below
SOURCE=forceDirCoeffs/forceDirCoeffs.C ;  icpc -std=c++0x -Dlinux64 -DWM_DP -wd327,654,819,1125,1476,1505,1572 -O2 -no-prec-div  -DNoRepository -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/finiteVolume/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/meshTools/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/sampling/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/transportModels -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/turbulenceModels -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/thermophysicalModels/basic/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/postProcessing/functionObjects/forces/lnInclude -IlnInclude -I. -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude -I/opt/app/OpenFOAM/OpenFOAM-2.2.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64IccDPOpt/forceDirCoeffs.o
forceDirCoeffs/forceDirCoeffs.C(33): error: name followed by "::" must be a class or namespace name
  defineTypeNameAndDebug(Foam::forceDirCoeffs, 0);
forceDirCoeffs/forceDirCoeffs.C(33): error #303: explicit type is missing ("int" assumed)
forceDirCoeffs/forceDirCoeffs.C(33): error: expected a ";"
forceDirCoeffs/forceDirCoeffs.C(91): error: identifier "forcesFilePtr_" is undefined
forceDirCoeffs/forceDirCoeffs.C(116): error: identifier "makeFile" is undefined
          makeFile();
forceDirCoeffs/forceDirCoeffs.C(118): error: identifier "forcesMoments" is undefined
forceDirCoeffs/forceDirCoeffs.C(137): error: identifier "forcesFilePtr_" is undefined
              forcesFilePtr_()
compilation aborted for forceDirCoeffs/forceDirCoeffs.C (code 2)
make: *** [Make/linux64IccDPOpt/forceDirCoeffs.o] Error 2
So i am not able to figure out how to debug this error it will be helpful if you can give some advice.
Thank you
Regards
Himanshu Sharma
himanshu28 is offline   Reply With Quote
Old   October 1, 2013, 06:32
ThienMa
luuhoangthien is on a distinguished road
Hi himanshu28
I Know this error, in the terminal you go to this folder and type follow me:
wclean
it will delete deb file
and now you type:
wmake libso
don't miss libso :P
Thien
luuhoangthien is offline   Reply With Quote
Old   October 2, 2013, 03:46
Smile Thanks
  #11
Himanshu Sharma
Originally Posted by luuhoangthien View Post
Hi himanshu28
if will delete deb file
and now you type:
don't miss libso :P
Thien
Thanks for the reply luuhoangthien it now worked..
Regards
Himanshu
Old   January 13, 2014, 10:58
Hi Bruno,
I try to add the modification to the OF V222, but i don't succeed.
I always have this error : "unknown function type force DirCoeffs".
When I add the modification like the previous OF version, I don't have error message, but the modification seems to not be affect.
Thank you in advance !
Old   January 13, 2014, 16:33
Bruno Santos
Hi Rider,
I won't have much time to look deeper into this before the weekend.
But one question: did you also try in OpenFOAM 2.2.1?
Either way, OpenFOAM 2.2 has been evolving on the function objects topic quite a bit, adding new features to them for 2.2.1, 2.2.2 and 2.2.x, so things have continued to change.
So it really depends on what was the starting point you've used to make the code modifications.
Best regards,
Bruno
Old   January 14, 2014, 03:46
Hi Bruno,
Thanks for your quick reply.
Yes, I have tried with the OF V221. The problem is the same.
I used your methode with the forceDirCoeff file.
Best regards.
Old   January 26, 2014, 12:28
Bruno Santos
Hi Rider,
OK, things did change considerably in OpenFOAM 2.2. It has got binning and all!
This time I've gone through the somewhat correct steps in sharing modified code, which is provided here: https://github.com/wyldckat/forceDirCoeffs
The instructions are provided there and make sure you replace all references to "21x" to "22x", when following the installation steps.
Let me know if you have any problems following the steps or any problems using the modified library.
Best regards,
Bruno
Old   February 5, 2014, 23:09
gsingle is on a distinguished road
Good day Bruno,
I have followed your most recent directions in the github site. I am running simpleFoam and it seems that the program is not picking up my forceDirCoeffs directory I have compiled. In my controlDict file I have placed #include "forceDirCoeffs" into the functions.
Below is found in my simpleFoam.log file. I think there must be a problem with the functionObject.C file in the OpenFOAM222 directory but do not know how to resolve it. Any help here would be much appreciated.
Thanks,
Geoff
[6] --> FOAM FATAL ERROR:
[6] Unknown function type forceDirCoeffs
Valid functions are :
20
cellSource
faceSource
fieldAverage
fieldCoordinateSystemTransform
fieldMinMax
fieldValueDelta
forceCoeffs
forces
nearWallFields
patchProbes
probes
processorField
readFields
regionSizeDistribution
sets
streamLine
surfaceInterpolateFields
surfaces
turbulenceFields
wallBoundedStreamLine
gsingle is offline   Reply With Quote
Old   February 6, 2014, 16:57
Bruno Santos
Greetings Geoff,
Mmm... I see that I need to provide clearer instructions on the README file...
The idea is that you should add the following line to the "controlDict" file:
libs (libforceDirCoeffs.so);
In case you already have a line that starts with "libs", then add the library name to the list, for example:
If you have this:
libs (
    libforces.so
It becomes this:
libs (
    libforces.so
Best regards,
Bruno
Old   February 8, 2014, 16:45
Thanks again for the help. I am running OpenFOAM 2.2.2. I did have to do one additional thing to the files I cloned from your github. Before the wmake command, I had to add lforces to the Make/options file, as seen below.
EXE_INC = \
-I$(LIB_SRC)/fileFormats/lnInclude \
LIB_LIBS = \
-lfluidThermophysicalModels \
-lspecie \
-lfiniteVolume \
-lmeshTools \
-lforces \
-lfileFormats
Works great now, I actually added a few terms, to give coefficients in all three directions in global coordinates as well as all three directions of local coordinates to the body being analysed.
wyldckat likes this.
Old   February 16, 2014, 12:43
Bruno Santos
Hi Geoff,
I've updated the repository, regarding the README file and the linking to "libforces" as you indicated.
Do feel free to clone the repository and publish your modifications to it!
Best regards,
Bruno
Old   March 27, 2014, 09:13
Let me finish my masters project first, then I will be more than happy to tidy up and post the updates. Just three more weeks!
Force can not converge colopolo CFX 13 October 4, 2011 22:03
How to measure side force and yawing moment firda FLUENT 0 November 3, 2010 02:33
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 08:58
