[OF 5.0] - declaring single variables
Old   May 24, 2018, 10:33
Default [OF 5.0] - declaring single variables
Gerry Kan's Avatar
Gerry Kan
Gerry Kan is on a distinguished road
Howdy folks:
I am wondering if there is a way to create individual variables at the beginning of solving, and let the solver change it through out.
In my solver, there are a number of solution domain independent variables (think g, but changes in value through time) and I would like to be able to update their values at the start of each iteration while allowing the solver variables (U, p, T, etc) to access them in the inner iteration. Since the value will be identifical to all cells, so I don't want to create an extra scalar to save space and computational effort. How could this be done?
Thanks in advance, GK.
Gerry Kan is offline   Reply With Quote
Old   May 28, 2018, 17:07
Default Turns out it wasn't so bad afterall
Gerry Kan's Avatar
Gerry Kan
So it was more straightforward than I thought. As I am still at the prototyping stage, I don't want to be too fancy with my code, but it looks like I can declare variables (scalars, bool, what not) at the solver level and have them accessible later. So for now my problem is solved.
But again, once my solver works, I should think about packaging these variables nicely (in a class, for instance).
Gerry.
Old   May 29, 2018, 09:46
Marius Bünker
Blumenkind is on a distinguished road
Declare them as Fields (for example VolScalarField)
OpenFoam recognizes that they are uniform for your domain and converts them to uniformField, which is saved as one Value and your BC.
Blumenkind is offline   Reply With Quote
Old   May 29, 2018, 10:39
akidess's Avatar
Anton Kidess
Why on earth would you run all the machinery to create a uniform field with boundaries, when all you need is a scalar?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 30, 2018, 01:43
Red face
Marius Bünker
You are right. I somehow thought, he wanted to save them and then he would have needed IOObjects.
Old   May 30, 2018, 16:52
Gerry Kan's Avatar
Gerry Kan
Hallo Blumenkind: That's the situation I want to avoid. But for now I am declaring them as "globals" and for now I am happy with it. The solver should have access to them in the inner / outer loops, should I need them.
VG, Gerry.
[swak4Foam] How to define boundary condition variables by using previosly defined variables? pawlo OpenFOAM Community Contributions 8 September 13, 2020 11:37
Single v.s. double precision Confused CFX 15 November 10, 2016 04:42
How to export single variable of a single surface? zeitistgeld CFX 6 September 26, 2009 06:37
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 11:44
