rotating source term using fvOptions
Like Tree2Likes
  • 1 Post By anon_q
  • 1 Post By C. Okubo
Old   October 16, 2018, 03:27
Default rotating source term using fvOptions
anon_q is on a distinguished road
Hello
In my simulation, I need to add a rotating source term to momentum equations without modifying the code of the solver.
Is it possible to use a rotating source term in fvOptions (has a distance R from the origin rotates about the origin (0,0,0) as a function of time and with given angular velocity)?
Please, can you give me an example?
PS: Without using MRF or Dynamic mesh.
C. Okubo likes this.
anon_q is offline   Reply With Quote
Old   October 29, 2018, 10:12
C. Okubo is on a distinguished road
Hi!
I am trying to do this also, but still not successful. Even though, SRFSimpleFoam is not an option for you?
Okubo
C. Okubo is offline   Reply With Quote
Old   October 29, 2018, 10:52
Tried some variations of the code below (in .../constant/fvOptions), but it is still not working well...
As far as I understand, this implements a explicit source...maybe, it should be implicit to work (like SRFSimpleFoam)?
Hope somebody can help...
|  \\    /   O peration     | Version:  v1806                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
velocitySource
    type            vectorCodedSource;
    vectorCodedSourceCoeffs
        selectionMode   all;
        fields          (U);
        name            vectorSource;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
	    vectorField& Usource = eqn.source();
            vector rotation = vector(0, 1, 0); // rotation in rad/s
	    const vectorField& radius = mesh_.C(); // center of cells (axis is considered passing through origin)
	    const vectorField& U_ = mesh().lookupObject<volVectorField>("U");
            Usource =  - (rotation^(rotation^radius)) - 2.0*(rotation^U_);
        codeSetValue
            Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
anon_q likes this.
Old   March 30, 2023, 04:55
ozi
Ph.D.(c) Oğuzhan KIRIKBAŞ
ozi is on a distinguished road
Did you get any progress with your code. I am struggling with the same issue. Code is working but the solution blows up very quick because of the large numbers produced by the additional source term.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
velocitySource
        selectionMode   all;
        fields          (U);
        name            vectorSource;
        codeInclude
        codeCorrect
        codeAddSup
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
ozi is offline   Reply With Quote
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 03:09
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
