"createBoxTurb" utility and "energySpectrum" function object from V1812
Old   February 17, 2019, 22:27
Default "createBoxTurb" utility and "energySpectrum" function object from V1812
DongHo
eddykendo is on a distinguished road
Dear. Foamers
I know there are a very useful utility, "createBoxTurb" and a function object "energySpectrum" available on V1812.
Because "createBoxTurb" is used for the decay of turbulence with LES, not DNS and energySpectrum for generating turbulent spectrum without any separate program using Matlab,
therefore, I have tried to compile those things in a local user directory on V4.0, not V1812. However, there were several compiling errors on V4.0.
Please give me any comment to correctly compile them on V4.0 or V4.x if you have experience like that.
Thank you.
eddykendo is offline   Reply With Quote
Old   February 18, 2019, 04:03
Michael Alletto
mAlletto will become famous soon enough
You have to check if all classes and functions used to construct boxTurb and energy spectrum used in 1812 are also present in v.4. Otherwise you have to copy this too and compile it. What I know there are different random number generator in 1812 compared to 4.0
mAlletto is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
How to create a function object in OpenFoam that runs properly ? mkhm OpenFOAM Programming & Development 1 October 20, 2018 16:16
coded function object and field average matthias OpenFOAM Post-Processing 3 June 30, 2014 04:52
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
