An implicit source term which is a function of several cell values.
Old   March 3, 2020, 18:53
Lightbulb An implicit source term which is a function of several cell values.
Kipri
foamnoob11 is on a distinguished road
Hello Foamers,
I'm trying to implement an implicit source term along the lines of fvm::Sp(coeff, f(U) ) for an
fvVectorMatrix quantity (namely U in this case) :
fvVectorMatrix UEqn (
            fvm::ddt(U)
          + fvm::div(phi, U)
          - fvm::laplacian(nu, U)
           ==  fvm::Sp(coeff, f(U))
where 'coeff' is an already defined volScalarField, f(U) --> is a vector quantity which is calculated as a weighted average (like a filter) of U from 'surrounding cells'
(this weighting calculation is done.)
Any ideas on how to implement such a source term implicitly ? (or any pointers where such a thing has been done? )
Thank you very much.
Kipri.
foamnoob11 is offline   Reply With Quote
Old   March 4, 2020, 04:45
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi Kipri,
I am now facing the similar problem like yours.
Now I need to implement the wall shear stress for solid phase (twophaseeulerfoam) through a source term in the momentum equation. The wall shear stress can be obtained via the following formular:
Sp=Tauw=alpha1*rho1*st*(U1.component(2).boundaryFi eld ()[patchi].patchInternalField())
*(U1.boundaryField()[patchi].patchInternalField() - U1.boundaryField()[patchi])
where "st" is the friction factor which should be calculated ieratively through
for (int i=0; i<10; i++)
st = sqr(kappa)/Log(E*Res*sqrt(st));
where "Res" is the Reynolds number of solid which calculated by Res=rho1*U1.component(2).boundaryField()[patchi].patchInternalField()*y[facei]/mus
However, now I wrote the codes in the Uequation but cannot be compiled. If you have some ideas, please tell me. Thanks.
qi.yang@polimi.it is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
