how to monitor the plusant velocity using swak4Foam
Old   March 25, 2020, 01:34
Default how to monitor the plusant velocity using swak4Foam
王子阳
wangziyang is on a distinguished road
hello everyone!
i want to output the pluse velocity during calculating time,so i insert the some functions to the ControlDict, they are as follows,
fieldAverage1
type fieldAverage;
functionObjectLibs ( "libfieldFunctionObjects.so" );
outputControl outputTime;
enabled true;
fields
U
mean on;
prime2Mean on;
base time;
uix
type expressionField;
autowrite true;
expression "U.x-UMean.x";
dimension [0 1 -1 0 0 0 0];
fieldName uix;
but when i run the programe, the error are as follows,
--> FOAM FATAL ERROR:
Parser Error for driver FieldValueExpressionDriver at "1.5-9" :"field UMean not existing or of wrong type"
"U.x-UMean.x"
why UMean not existed? i also use the fieldaverageFunction to output it
anyone can help me?
best wishes!
ziyang
wangziyang is offline   Reply With Quote
monitor plusant velocity
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 06:26
Jumping droplets velocity - interFoam Zinedine OpenFOAM Running, Solving & CFD 0 October 6, 2015 08:25
[swak4Foam] problem with a parabolic velocity profile Claudio87 OpenFOAM Community Contributions 5 May 29, 2014 09:30
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
