Failed wmake when using scalaCodedSource in fvOptions |
August 10, 2020, 04:18 |
Unn
I am currently struggling with setting up coded source via fvOptions. I have looked at previous discussions on this forum about this and used them as guideline, for instance, in creating the following momentum source term: Code:
momentumSource { type vectorCodedSource; active on; name sourceTime; vectorCodedSourceCoeffs { fields (U); selectionMode all redirectType sourceTime; codeInclude #{ #}; codeCorrect #{ Pout<< "**codeCorrect**" << endl; #}; codeAddSup #{ const scalarField& V = mesh_.V(); vectorField& USource = eqn.source(); USource += (100 1 1)*V; // Definition of the user-defined momentum source term #}; codeSetValue #{ Pout<< "**codeSetValue**" << endl; #}; // Dummy entry. Make dependent on above to trigger recompilation code #{ $codeInclude $codeCorrect $codeAddSup $codeSetValue #}; } sourceTimeCoeffs { // Dummy entry } } Code:
Invoking "wmake -s libso /home/user/CFDEM/user-PUBLIC-5.x/run/Original/CFD/dynamicCode/heatSink" sh: 1: Syntax error: "(" unexpected [0] [0] [0] --> FOAM FATAL IO ERROR: [0] Failed wmake "dynamicCode/heatSink/platforms/linux64GccDPInt32Opt/lib/libheatSink_7946a6c1177d969821ce64c8d265d148e8176c3e.so" [0] [0] [0] file: /home/user/CFDEM/user-PUBLIC-5.x/run/Original//CFD/constant/scalarTransportProperties.generalManualProps.fvOptionsT.scalarCodedSourceCoeffs from line 67 to line 101. [0] [0] From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const [0] in file db/dynamicLibrary/codedBase/codedBase.C at line 206. [0] FOAM parallel run exiting [0] Could any experienced users provide insights into this issue? Thank you very much. PS. I'm running a CFD-DEM simulation using CFDEM project - I'm not sure if this has anything to do with the error, but from my understanding fvOptions is initiated independent of the coupling. |
fvoptions |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 13:28 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
