Compile boundary condition as a new dynamic library
Like Tree5Likes
Old   May 23, 2010, 13:06
Default Compile boundary condition as a new dynamic library
Mohan
mohanphy is on a distinguished road
Dear All,
I am trying to Compile boundary condition as a new dynamic library. I following this tutorials: http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29
I have done the following steps :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived$ svn checkout http://openfoam-extend.svn.sourcefor...bolicVelocity/
A parabolicVelocity/parabolicVelocityFvPatchVectorField.C
A parabolicVelocity/parabolicVelocityFvPatchVectorField.H
U parabolicVelocity
Checked out revision 1738.
I have downloaded it :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived$ cd parabolicVelocity/
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ ls
parabolicVelocityFvPatchVectorField.C parabolicVelocityFvPatchVectorField.H
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ mkdir Make
Make parabolicVelocityFvPatchVectorField.H
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ cd Make/
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ vim files
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ vim options
wmake will show the following message :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file parabolicVelocityFvPatchVectorField.C
SOURCE=parabolicVelocityFvPatchVectorField.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/parabolicVelocityFvPatchVectorField.o
'/home/openfoam/OpenFOAM/openfoam-1.6/lib/linuxGccDPOpt/libmyBCs.so' is up to date.
lnInclude parabolicVelocityFvPatchVectorField.C parabolicVelocityFvPatchVectorField.H
Make parabolicVelocityFvPatchVectorField.dep
It has successfully creates "libmyBCs.so" in /home/openfoam/OpenFOAM/openfoam-1.6/lib/linuxGccDPOpt/libmyBCs.so
The tutorials saying that I need to add the following line in system/controlDict file: libs ("libmyBCs.so");
The problem is I don't know where is the system/controlDict file (absolute path). some one please explain me to find system/controlDict file.
Thanks & Rg
Mohan L
mohanphy is offline   Reply With Quote
Old   March 22, 2013, 09:42
starter
sihaqqi is on a distinguished road
Mohan
I am after this parabolic velocity patch .C and .H. I use openFoam 2.1. the link you have given does not have these files. Can you please post these. The need is very urgent because first I have to understand them as a beginner in OpenFoam and then I shall have to convert in 1/7th power law.
I shall be grateful
regards
sihaqqi is offline   Reply With Quote
Old   March 24, 2013, 14:01
Retired Super Moderator
Bruno Santos
Greetings sihaqqi,
They are available here: https://github.com/ogoe/OpenFOAM-1.6...bolicVelocity/
Direct links:
Best regards,
Bruno
Old   March 24, 2013, 18:26
starter
Dear Bruno
Many thanks for this.
Thanks & Regards
Sihaqqi
Old   March 25, 2013, 02:26
starter
Bruno
Can you please advise where I can get Make files and options from for this thing
Regards
Old   March 25, 2013, 15:57
Bruno Santos
It's explained in the first link on this thread: http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29
Old   July 25, 2013, 06:22
nadine moussa
nadine is on a distinguished road
I don't know if I am really unlucky, but none of the links refering to parapolicVelocity are working!!!
Can someone help me and post a valid link so I can add this condition and compile it?
Thanks a lot,
Nadine
nadine is offline   Reply With Quote
Old   July 25, 2013, 09:48
nadine moussa
Re-Hello,
Finally i found source files using this link:
https://github.com/Unofficial-Extend...eld.H.svn-base
I saved both the .C and .H in a file outside openfoam and followed the instructions givin in wiki to add my library and linked it dynamically by adding libs ("libmyBCs.so"); in my controlDict.
Than I ran the simulation but I got an error message, indicating that there is no such a boundary condition and giving me choices between the classical boundaries found in openfoam!!!
what did I do wrong and how can I fix it!
Help!
Waiting for your answers, even if it s summer time
Nadine,
Old   July 25, 2013, 11:17
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Originally Posted by nadine View Post
Re-Hello,
Help!
Nadine,
Can you, please, post your case files?
alexeym is offline   Reply With Quote
Old   August 18, 2013, 12:21
Bruno Santos
Greetings to all!
@Nadine: I don't know if you've fixed the problem you reported about, but here is summary and updated building instructions, based on 1.6-ext and http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29 - edit: and yes it should work for almost any version of OpenFOAM!
Run these commands:
mkdir -p $FOAM_RUN
cd $FOAM_RUN/..
mkdir parabolicVelocity
wget "http://sourceforge.net/p/openfoam-extend/OpenFOAM-1.6-ext/ci/master/tree/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/parabolicVelocityFvPatchVectorField.C?format=raw" -O parabolicVelocityFvPatchVectorField.C
wget "http://sourceforge.net/p/openfoam-extend/OpenFOAM-1.6-ext/ci/master/tree/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/parabolicVelocityFvPatchVectorField.H?format=raw" -O parabolicVelocityFvPatchVectorField.H
mkdir Make
echo 'parabolicVelocityFvPatchVectorField.C'  > Make/files
echo 'LIB = $(FOAM_USER_LIBBIN)/libmyBCs'  >> Make/files
echo 'EXE_INC =  -I$(LIB_SRC)/finiteVolume/lnInclude'  > Make/options
echo 'EXE_LIBS = '  >> Make/options
wmake libso
The I used the tutorial "incompressible/simpleFoam/pitzDaily" as basis and edited the files:
  • "system/controlDict" - Added the line:
  • "0/U" - changed the BC "inlet" to this:
        inlet
            type            parabolicVelocity;
            n               (1 0 0);
            y               (0 1 0);
            maxValue        1;
            value           (0 0 0); // Dummy for paraFoam, which will NOT show a correct profile at time 0.
Then to run the case, I simply run:
blockMesh
simpleFoam
Best regards,
Bruno
mgg, hiuluom, k.farnagh and 1 others like this.
Old   January 2, 2014, 10:29
Tony
wzx1989221 is on a distinguished road
Dear Bruno,
I find your post very useful. Just want to know if it is possible to do the parabolic inlet in that way using OF 2.1? Or is it only applicable in OF 1.6-ext version?
Looking forward to your reply. Thank you very much.
Best regards,
Tony
wzx1989221 is offline   Reply With Quote
Old   January 2, 2014, 18:22
Bruno Santos
Greetings Tony,
Good question! I've updated post #10 to add a note about that.
I forgot to mention back then, but it's sort-of implied that these instructions are for any OpenFOAM version, but rely on the source code of OpenFOAM-1.6-ext. Actually, now it's foam-extend 3.0, but this boundary condition is pretty much the same .
Best regards,
Bruno
Old   January 2, 2014, 19:02
Tony
Dear Bruno,
Thank you very much for the reply. Actually I have checked out that it works well with OF 2.1.
One thing is that I tried to use it for 3D pipe flow, but the profile turned out to be varying in only one direction like in channel. Any suggestions on making it work for pipe?
Best regards,
Tony
Old   January 2, 2014, 19:40
Bruno Santos
Hi Tony,
Mmm... what you are looking for is a paraboloid: http://en.wikipedia.org/wiki/Paraboloid
But this boundary condition from 1.6-ext is only "parabolic"
The idea is that you need to modify the source code of the method "updateCoeffs()". Essentially, you need to modify these two lines of code:
 // Calculate local 1-D coordinate for the parabolic profile
scalarField coord = 2*((c - ctr) & y_)/((bb.max() - bb.min()) & y_);
vectorField::operator=(n_*maxValue_*(1.0 - sqr(coord)));
Right now I don't have much time to look into this. But let me know if you don't manage to solve this by yourself. And if you are able to, do share the solution!
Best regards,
Bruno
Old   January 3, 2014, 08:34
Tony
Hi Bruno,
Many thanks for the tips. I will look into that to see if I can resolve it. I will share the solution if I make it.
Regards,
Tony
vipin1431 likes this.
Old   August 6, 2015, 06:20
vipin
vipin1431 is on a distinguished road
Hi Bruno,
Regards,
Tony
hi tony,
I followed the above instruction to get parabolic inlet velocity and also i got same profile like i.e. variation along one direction only did you get it corrected....if yes, please help me to correct it.
regard
vipin
vipin1431 is offline   Reply With Quote
Old   August 23, 2016, 08:46
Rudolf Hellmuth
rudolf.hellmuth is on a distinguished road
Paraboloid velocity profile on a circular patch:
    inlet
        type            codedFixedValue;
        value           uniform (0 0 0);
        redirectType    Poiseuille;
        code
            const fvPatch& boundaryPatch = patch();
            const vectorField& Cf = boundaryPatch.Cf();
            vectorField& U = *this;
            //gfunc calculates the function on decomposed patches for parallel runs.
            scalar patchArea = gSum(boundaryPatch.magSf());
            //Info << "Patch area: " << patchArea << endl;
            vector ctr = gSum(boundaryPatch.magSf()*Cf)/patchArea;
            //Info << "Patch center: " << ctr << endl;
            scalar R = sqrt(patchArea/constant::mathematical::pi);
            //Info << "Patch radius: " << R << endl;
            vector n = gSum(boundaryPatch.magSf()*boundaryPatch.nf())/patchArea;
            //Info << "Patch mean normal: " << normal << endl;
            scalar Umean = 1.0;
            forAll(Cf, i)
                U[i] = -n*2.0*Umean*(1.0 - sqr(mag(Cf[i] - ctr)/R));
            // operator==(vector(1.0, 0.0, 0.0));
This codedFixedValue BC is working for me. You can use this code to compile a PoiseuilleBC.so if you want.
I hope it can help you,
Rudolf
rudolf.hellmuth is offline   Reply With Quote
Old   November 18, 2016, 07:40
Default Paraboloid velocity profile on a square channel ?
  #18
vidyadhar
vidyadhar is on a distinguished road
    inlet
        code
            scalar Umean = 1.0;
            forAll(Cf, i)
Rudolf
Hello Rudolf,
I have seen your post on paraboloid profile for a circular patch.
I would like to implement paraboloid profile for a square patch, since, in my case, I have to give fully developed profile at the inlet to a square channel.
Can you help me in implementing the same.
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   November 18, 2016, 08:51
Rudolf Hellmuth
Originally Posted by vidyadhar View Post
Hello Rudolf,
I can easily help you to make this "paraboloid" if your rectangular patch is on a plane orthogonal to the Cartesian coordinates. If it is diagonal to the Cartesian coordinates, then you'd have to either give the patch orientation as input, or you'd have to figure out a way of obtaining the patch orientation with the patch data.
Try this:
// patch area
    scalar A = gSum(patch().magSf());
    // patch normal vector is the weighted mean of patch face normal
    // vectors
    vector np = gSum(patch().magSf()*patch().nf())/A;
    // patch centre is the weighted mean of patch face centres
    vector O = gSum(patch().magSf()*patch().Cf())/A;
    // local position of cell centres (referenced on the patch centre)
    scalarField pos = mag(patch().Cf() - O);
    // patch lengths on x and y directions
    scalar X = 1.0;
    scalar Y = 1.4;
    fixedValueFvPatchVectorField::operator==
      -np*vmean*2.0 *(1.0 - sqr(pos.x()/X))*(1.0 - sqr(pos.y()/Y))
I haven't tested that, it's just an idea. There are two parabolas, one on the x direction and the other on the y direction. I hope this code can help you.
Good luck!
Rudolf
Old   November 18, 2016, 09:07
vidyadhar
Hello Rudolf,
Thank you for the immediate help.
I will test the code and get back to you with the outcomes.
Thanks & Regards,
vidyadhar
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
How to define a dynamic Boundary Condition? abrahamgx CFX 2 March 9, 2009 23:03
How to define a dynamic Boundary Condition? (New) abrahamgx CFX 2 March 9, 2009 07:43
Dynamic Temperature Boundary Condition Kshitij FLUENT 0 October 12, 2005 13:40
