compiling a new solver using older one
Old   October 7, 2021, 07:33
Default compiling a new solver using older one
kuldeep
kuldeep is on a distinguished road
i am new to this openfoam, i am trying to add extra term(T j in momentum equation and n^2 * V in energy equation) and trying to compile it but getting this error:
candidate expects 2 arguments, 1 provided
71 | +fvc::Sp(T));
form of equation which i want in to add in my solver
https://drive.google.com/file/d/1rzd...ew?usp=sharing
new_Icofoam3.C
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Copyright (C) 2011-2018 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
new_icoFoam
Description
Transient solver for incompressible, laminar flow of Newtonian fluids.
Added the temperature solver
#include "fvCFD.H"
#include "pisoControl.H"
int main(int argc, char *argv[])
#include "setRootCaseLists.H"
#include "createTime.H"
#include "createMesh.H"
pisoControl piso(mesh);
#include "createFields.H"
#include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "CourantNo.H"
// Momentum predictor
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
if (piso.momentumPredictor())
solve(UEqn == -fvc::grad((1/rho)*p)
+fvc::Sp(T));
// snGrad calculates the surface normal gradient for you. Since the surface normal
// is only one direction, you will get one component for every component of velocity.
// However if you input a scalar field, you will get only a scalar.
// --- PISO loop i.e correcting the velocity
while (piso.correct())
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
surfaceScalarField phiHbyA
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
adjustPhi(phiHbyA, U, p);
// Update the pressure BCs to ensure flux consistency
constrainPressure(p, U, phiHbyA, rAU);
// Non-orthogonal pressure corrector loop
while (piso.correctNonOrthogonal())
// Pressure corrector
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (piso.finalNonOrthogonalIter())
phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
/* here velocity is already calculated */
// now start the temperature equation part
// int N2;
// I = [0 1 0]
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T) // DT for thermal diffusivity
+ N2*(U&I)); // & operator is for dot product
//TEqn.relax()
TEqn.solve();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
createfields.H
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
dimensionedScalar nu
"nu",
dimViscosity,
transportProperties.lookup("nu")
// Adding Line
dimensionedScalar DT
"DT",
// dimViscosity,
transportProperties.lookup("DT")
dimensionedScalar N2
"N2",
transportProperties.lookup("N2")
dimensionedScalar rho
"rho",
transportProperties.lookup("rho")
dimensionedVector I
"I",
vector (0, 1, 0)
// Done
Info<< "Reading field p\n" << endl;
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Info<< "Reading field U\n" << endl;
volVectorField U
IOobject
"U",
runTime.timeName(),
mesh,
mesh
// Adding lines for temperature field
Info<< "Reading field T\n" << endl;
volScalarField T // T is also volume property
IOobject
"T",
runTime.timeName(),
mesh,
mesh
// Done
#include "createPhi.H"
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("PISO"), pRefCell, pRefValue);
mesh.setFluxRequired(p.name());
please help me with this
thanks in advance
kuldeep is offline   Reply With Quote
make: Clock skew detected. build may be incomplete. while compiling new solver. savee OpenFOAM Programming & Development 1 May 27, 2017 06:23
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 08:05
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
