output stream file in scientific notation
Like Tree1Likes
  • 1 Post By Voulet
Old   April 12, 2022, 01:15
Default output stream file in scientific notation
Voulet is on a distinguished road
Hello. I didn't find any relevant post while googling this thus for future generation here is how to output some values in scientific notation. The key here is the following line :
mySuperStream.setf(ios_base::scientific, ios_base::floatfield);
// near your CreateField outside main loops
OFstream mySuperStream((string("Coucou")));
mySuperStream.precision(5);
mySuperStream   << "Time" << tab
                << "sumMatter" << tab
                << "Pthermique" << tab
                << "diff_pression"<< tab
                << "Joth"<< tab
                << endl;
// inside your loop
if (Pstream::master()) {
    mySuperStream <<    U.db().time().value() << tab
                            << sumMatter << tab
                            << Pthermique << tab
                            << diff_pression << tab
                            << Joth << tab
                            << endl;
Happy foaming.
Kummi likes this.
« Debugging is what CFD is about. 5 minutes to modify your code, 5 months to find why it does not work anymore. »
Voulet is offline   Reply With Quote
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
