Calculation of interface area interFoam / VoF |
May 11, 2022, 11:20 |
Rep Power: 4 |
Peace Foamers,
I'm currently implementing an evaporation model and for that, I need the interface Area between my two phases alpha1 and alpha2. Does anyone know how to do that? I assumed that one of the interface reconstruction methods would deliver a function that could be called or the class surfaceInterpolation but I havent found anything suitable there. (btw. I'm not greatly familiar with PLIC, isoAdvector, etc.) My first thought of an apporach looked like that: 1.) Identifying interface cells (e.g. alpha = 0.5) 2.) Then calculate the volume occupied by alpha for each of these interface cells (mesh.V()*alpha1) 3.) calculate normal vector with nHat = grad(alpha)/mag(grad(alpha)) to get information about the orientation of that approximated interface plane ______________ Now the part where I dont know how to proceed Here I thought about an algorithm that is starting from a suitable point. I try to explain it in a simple case: 2D Square. Starting from a corner then follow the diagonal and calculate a orthogonal line where both ends of this line touch the sides of that square. This will be continued until the areas (equivalent to the volume in 2.)) will match. The resulting length(area) is what can be used for the calculation. Has someone an idea how to realize that - or even better: Is there something which gives me the interface area between both phases without a complicate implementation? Kind regards and a thank you in advance! Last edited by überschwupper; May 12, 2022 at 04:51. |
August 3, 2022, 04:19 |
Found a solution?
Julian Re
Rep Power: 4 |
Hey überschwupper,
basically I need a pretty similar procedure to detect collisions between two flow fronts of alpha1... (track interface (get element attributes to current interface elements etc,). You already found a good way? There must be some function in interFoam to get the interface elements (eg. based on the gradient of alpha?). Tank you in advance! Julian |
August 3, 2022, 06:57 |
Rep Power: 4 |
Hey, there is a function that already tracks interface elements (coming from the interfaceProperties class inhereted by incompressibleTwoPhaseMixture - nearInterface()) but anyway.. This interface area calculation is still open for me.
August 16, 2022, 07:03 |
hari charan
Rep Power: 4 |
Hi uberschwupper,
I have a similar doubt. I wnat to find the distance between cell center and interface. Do you have any idea about that? Thanks in advance |
August 16, 2022, 08:17 |
Santiago Lopez Castano
August 16, 2022, 08:22 |
hari charan
Rep Power: 4 |
Hi Santiago
mag(fvc::grad(alpha1))*mesh().V()it has the dimensions of area. fvc::grad(alpha1) has dimensions 1/length and mesh.V() has dimensions Length*Length*Length. Do you know how to find the distace from cell center to interface. Thanks in advance |
August 16, 2022, 08:31 |
#7 | |
X_\Gamma = X_P + \zita times d_f where \zita = \frac{\alpha_P -0.5}{\alpha_P - \alpha_N} |
August 16, 2022, 08:34 |
hari charan
Rep Power: 4 |
Hi santiago,
I am new to foam can I have a detailed explaination? I don’t know what alpha_n alpha_p and d_f are. Thanks and regards |
August 16, 2022, 08:36 |
August 16, 2022, 08:56 |
hari charan
Rep Power: 4 |
Hi santiago,
I mean P and N indicate alpha1 at owner and neighbour cells? Can you please post equation of zeta in mathematical form instead of code? Thanks and regards |
August 16, 2022, 09:02 |
#11 | |
\zita = (\alpha_P - 0.5)/(\alpha_P - \alpha_N) |
August 16, 2022, 09:04 |
#12 |
hari charan
Rep Power: 4 |
P and N indices are for current cell and neighbour cell right?
August 16, 2022, 09:06 |
#13 |
August 16, 2022, 09:07 |
#14 |
hari charan
Rep Power: 4 |
Thank you santiago I will try this out .
August 17, 2022, 00:05 |
#15 |
hari charan
Rep Power: 4 |
Hi santiago ,
Can you please tell me what does zita physically means? Can I get the physical significance of zita? I implemented code in this way but I am getting large value of center to interface distance . value is around 500. Can you look into it and suggest any changes? Or if you have any code sample please give me. const unallocLabelList& neighbour = mesh.neighbour(); const unallocLabelList& owner = mesh.owner(); const volVectorField& C = mesh.C(); const volScalarField& T = alpha1().db().lookupObject<volScalarField>("T"); //const surfaceScalarField& deltas = mesh.deltaCoeffs(); //const dimensionedScalar len("len",dimLength,1/mag(deltas)); volScalarField zita ("zita", 0*limalpha1); vector delta(0,0,0); const dimensionedScalar len("len",dimLength,0); const dimensionedScalar smallValue("smallValue",dimLength,1e-5); const dimensionedScalar secondValue("secondValue",dimensionSet(1,-2,-1,0,0,0,0),0.0 ); //const volScalarField thirdValue("thirdValue",1e-6 * limalpha1); forAll(owner, facei) { zita = (limalpha1[owner[facei]] - 0.5)/(max((limalpha1[owner[facei]] - limalpha1[neighbour[facei]]),value)); vector delta = C[neighbour[facei]] - C[owner[facei]]; const dimensionedScalar len("len",dimLength,mag(delta)); //Info << "zita: " << max(zita).value() << " ND" <<endl; //Info << "len: " << len.value() << " m" <<endl; } return Pair<tmp<volScalarField>> ( (limalpha1*lambda1_+ (1-limalpha1)*lambda2_) * ((T-Tsat_)/(max((mag(C)+(zita*len)),smallValue)*h_lv_)),limal pha1 * 0.0 * secondValue ); } Thanks in advance Last edited by saicharan662000@gmail.com; August 17, 2022 at 03:41. |
August 17, 2022, 04:18 |
#16 | |
If you need the distance to the interface from ALL CELLS then you not only need to determine the distance to the interface centroids, but you need to solve a Poisson equation for coordinate quantities wrt the interface location. The faceMeshWave, and meshWave class may help you with that. You may get some inspiration from some wall & turbulence models where the distance from the wall is needed. |
August 17, 2022, 04:21 |
#17 |
hari charan
Rep Power: 4 |
Hi santiago,
I don’t need distance from every cell . Just from the cell center to the cell containing interface. Can you attach any code sample if possible? or please tell me how to get X_p and alpha values of owner and neighbor cells in openfoam. Thanks in advance |
August 19, 2022, 09:53 |
#18 | |
August 19, 2022, 11:03 |
#19 |
hari charan
Rep Power: 4 |
Hi santiago,
So I should use for loop instead of forAll . I am not getting idea how to implement it with for loop. Because If I implement it with for loop I will have 2 return statements. One for non interface cells and other is for interface cells. Can you attach code snip if you have it? Thanks in advance |
interface curvature in interFoam | ndtrong | OpenFOAM Programming & Development | 4 | December 22, 2019 22:49 |
Access the area and normal of the interface in VOF | dongshancfd | Fluent Multiphase | 0 | March 6, 2018 03:56 |
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
