Overset mesh for Fluid Structure Interaction in OpenFOAM |
June 20, 2018, 19:27 |
Thaw Tar
Rep Power: 13 |
Hello everybody.
I want to use overset mesh for fluid structure interaction like those in the third figure of the attached picture below. I think Official OF1706 or OF1712 do not have fluid structure interaction facilities like fsiFoam available for foam-extend 3.2 or 4.0. Thus, I think it is better to use overset mesh with foam-extend. I asked Prof. Hrvoje Jasak for overset code in Foam-Extend. He kindly provided me with Foam-Extend 4.1 code (It is not officially released yet. But you can email to Prof. Jasak if you want to try). But as far as I understand, this code focuses on solid body motion rather than deformed patches. For me, I need to deform the overset mesh while the background mesh is not changed. In other words, the whole overset domain (I am not sure I should use the word 'domain') should deform properly so that I can maintain mesh quality. I guess I need to write a mesh motion solver for overset mesh region. Any help will be greatly appreciated. |
July 21, 2020, 11:53 |
Hello Thaw,
Did you figure out how to deform the overset body? In addtion, do you know how to deform the background mesh with overset? I try to use overset mesh in a deforming background mesh. I noticed dynamicOversetFvMesh is derived from dynamicMotionSolverFvMesh which means overset should be able to coupled with dynamic motion solver like velocity/dispalcementLaplacian. But I do not know how to set up the dynamicMeshDict. Do I need write code to integrate overset with deforming? Thank you! Michael |
February 19, 2022, 01:54 |
TWB
Rep Power: 19 |
Anyone manage to get it working - overset mesh with deformation?
I wonder if it is possible, or the source code must be modified to make it work this way. |
February 19, 2022, 20:53 |
TWB
Rep Power: 19 |
August 25, 2023, 17:56 |
#5 | |
Manchester
Rep Power: 3 |
How are you doing? I have the same problem with using flexible overset mesh on OpenFOAM, have you managed to solve this problem? Best, Tian |
fsi, overset mesh |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Heat transfer and fluid structure interaction at OpenFOAM Workshop Milan 2008 | ztukovic | OpenFOAM | 0 | March 28, 2008 11:17 |
