Variation of gravity with time
Like Tree4Likes
Old   January 13, 2010, 11:28
Question Variation of gravity with time
Stefano
Whyman is on a distinguished road
Dear OpenFoam users,
i'm trying to simulate the effects of the acceleration's variation of a rocket on a particular experiment. My problem is that the acceleration value varies with the mission time.
Does anyone know how to set the variation of the gravity with the time?
Thank you
Bye
Whyman is offline   Reply With Quote
Old   January 14, 2010, 23:43
openfoam1 is on a distinguished road
Whyman thanks for posting this thread ,, I'm too have a simulation that need variation of gravity with time ,, also i want to know how to implement centrifugal force in openFoam
regards
openfoam1 is offline   Reply With Quote
Old   January 16, 2010, 06:12
Claus Meister
idrama is on a distinguished road
Had you guys a look at the sloshing tank tutorial:
tutorials/multiphase/interDyMFoam/ras/sloshingTank2D
This will properly match you expectation.
kinda regards
idrama is offline   Reply With Quote
Old   January 17, 2010, 00:05
kinda regards
hi idrama
thank you ,, it is a rotating wall boundary condtion
do you know how to implement a given body force ( and also how to make it vary with time ) in to the solver governing equations ' interFoam ' for example
Old   January 17, 2010, 00:48
Alberto Passalacqua
Originally Posted by openfoam1 View Post
hi idrama
look at how the gravity is implemented in interFoam, by means of its contribution to the flux.
In the momentum predictor, if solved, the gravity is not included in the matrix but added on the RHS of the equation as (UEqn.H)
fvc::reconstruct(fvc::interpolate(rho)*(g & mesh.Sf()))
and its contribution to the flux is accounted for as (pEqn.H)
phi = phiU + (fvc::interpolate(rho)*(g & mesh.Sf()))*rUAf;
You can do the same for other body force terms, starting from the semi-discrete form of the momentum equation and deriving the expression for the flux contribution of the additional term.
If you simply want the gravity to change with time, simply remove
  • Remove #include "readGravitationalAcceleration.H"
  • Define a volVectorField that contains your gravitational acceleration, depending on the current time
    • volVectorField g = <put your expression here>;
Best,
jiadongw likes this.
Alberto Passalacqua
Old   January 18, 2010, 04:30
Thumbs up
Stefano
Alberto,
thanks for your useful reply.
I just have only one more question about this topic.
You suggested to write a particular expression for the gravity. What am i supposed to do in case i have a list of gravity values for each flowtime, which do not respond to a specific expression?
For example, if i have this type of gravity data file:
flowtime gx gy gz
0.1 0.1 0.1 1
0.15 0.2 0.1 1.5
0.2 0.8 -0.5 1.5
Finally, is it possible to apply this variation to OpenFoam version 1.5?
Thank you
Regards
Old   January 18, 2010, 06:11
Claus Meister
Hello Alberto,
in my case the gravity only turns about the y-axis in 4 sec. So I changed the code according to your last post as follows:
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
//#include "readGravitationalAcceleration.H"
volVectorField g=-9.81*vector(0,0,1); // There may be dependencies in the next includes.
#include "readPISOControls.H"
#include "initContinuityErrs.H"
#include "createFields.H"
#include "readTimeControls.H"
#include "correctPhi.H"
#include "CourantNo.H"
#include "setInitialDeltaT.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.run())
#include "setDeltaT.H"
runTime++;
g=9.81*sin(pi/4*runTime)*vector(1,0,0)-9.81*cos(pi/4*runTime)*vector(0,0,1);
Info<< "Time = " << runTime.timeName() << nl << endl;
But when I am compiling it the compiler ends up with an error message. What did I wrong?
kinda regards
Claus
Old   January 18, 2010, 13:28
Alberto Passalacqua
Originally Posted by Whyman View Post
Alberto,
flowtime gx gy gz
0.1 0.1 0.1 1
0.15 0.2 0.1 1.5
0.2 0.8 -0.5 1.5
Well, it might not be the most elegant way, but a quick one could be to write a function that returns the gravity value checking the time range.
In pseudo-code
if (t <= 0.1)
g = (0.1 0.1 1)
else if (0.1 < t < 0.15)
g = (0.1 0.2 1.5)
else if (...)
[QUOTE
Yes. In OF 1.6 the gravity field has been redefined in a slightly different way than in 1.5, but this should not make a big difference.
Best,
Alberto Passalacqua
Old   January 18, 2010, 13:43
Alberto Passalacqua
Hello Alberto,
runTime++;
kinda regards
Claus
Without the error message, it is a bit hard :-)
However, here
you use runTime in the wrong way. It is a Time object, but what you need is your current time, which is provided by runTime.timeName().
In addition, you do not provide the correct units to g, so the solver will complain when running. You can define a multiplier with the correct units as
const dimensionedScalar gunits("gunits", dimensionSet(0,1,-2,0,0,0,0), 1.0);
and multiply your value by it.
Best,
Alberto Passalacqua
Old   January 23, 2010, 09:28
Claus Meister
Hello Alberto,
for one week I am trying it to get the code going. I modified the code as follows:
vector g0(0,0,9.81);
dimensionedVector g("g",dimensionSet(0,1,-2,0,0,0,0),g0);
runTime++;
g0=9.81*sin(runTime.timeName()*pi/4.0)*vector(1,0,0)-9.81*cos(runTime.timeName()t*pi/4.0)*vector(0,0,1);
By compinling I get the error message:
MyInterFoam.C:87: error: no match for ‘operator*’ in ‘Foam::Time::timeName() const() * 3.141592653589793115997963468544185161590576171875 e+0’
/home/idrama/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionSet.H:266: note: candidates are: Foam::dimensionSet Foam:perator*(const Foam::dimensionSet&, const Foam::dimensionSet&)
As far as I figured out the problem is that I have double operation * but the data type of tunTime.timeName() is word. How can I get a double value from runTime? Or, in general, what I have to to else to get the code running?
Cheers,
Claus
Old   January 23, 2010, 13:43
Alberto Passalacqua
Hello Alberto,
runTime++;
Cheers,
Claus
The problem is in how you set the dimensions. Replace
with
dimensionedVector g0=9.81*gunits*sin(runTime.timeName()*pi/4.0)*vector(1,0,0)-9.81*cos(runTime.timeName()t*pi/4.0)*vector(0,0,1);
and remove the definition of vector g0 at the beginning.
In other words you define a constant, of magnitude 1 with the dimensional units of an acceleration, and you use it as a multiplier for your vector, to set the appropriate unit.
Best,
tonnykz likes this.
Alberto Passalacqua
Old   January 23, 2010, 16:58
Claus Meister
Thanks All!
PROBLEM SOLVED, MISSION ACCOMPLISHED:
#include "fvCFD.H"
#include "MULES.H"
#include "subCycle.H"
#include "interfaceProperties.H"
#include "twoPhaseMixture.H"
#include "turbulenceModel.H"
#define pi 3.141592653589793238
const dimensionedScalar gunits("gunits", dimensionSet(0,1,-2,0,0,0,0), 9.81);
runTime++;
g=gunits*Foam::sin(runTime.value()*pi/4.0)*vector(1,0,0)-gunits*Foam::cos(runTime.value()*pi/4.0)*vector(0,0,1);
Kinda regards!
Claus
pruthvi1991 and tonnykz like this.
Old   January 23, 2010, 17:09
Alberto Passalacqua
Good! And you found part of the answer yourself, since I misled you with timeName(). Sorry about that
Best,
Alberto Passalacqua
Old   January 24, 2010, 17:38
Lightbulb
  #14
Hi alberto ;
i want to make the gravity vector constant in magnitude but rotates with a known omega ,, and in the same situation there exist a constant centrifugal force (constant magnitude and constant direction).. both in one simulation
gravity vector rotates (omega) + centrifugal force (constant vector)
does it possible to do that in the runtime as in the previous case ?
best regards.
Old   January 30, 2010, 03:02
Best,
Hi alberto ;
best regards.
Old   February 8, 2010, 11:47
Question further problems
  #16
Stefano
Hi guys,
i would like to replace my problem, beacause i can't solve it yet.
Alberto wrote about a pseudo-code for the gravity in case i had random values.
My problems is: what happens if i have a list of thousands values of g?
My idea is the following.
1) To write a gravity file as a text file with all the x,y,z values
2) To write the time file with the list of the time values
3) Every time-step, the solver will read these two files (g and t) and change the g-value in the "g" file of the case contained in the "constant" directory
4) The solver keep calculating and cycle it.
Alternatively i received this comment:
Obviously the standard OpenFOAM solvers don't include the variation in
gravity - most of them apply to flows in a stationary reference frame
on Earth!
If you want to use data from a file whose values you wish to
interpolate between, there is a class set up for this called
interpolationTable<Type>. You could use this for a vector quantity,
by constructing an interpolationTable<vector>. There are a choice of
constructors that take a file name, or dictionary entry for the file
name as arguments, see:
$FOAM_SRC/OpenFOAM/interpolations/interpolationTable/interpolationTable.C
Some time varying boundary conditions use the same class to handle
time-value data. Examples are:
$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/timeVaryingFlowRateInletVelocity/
$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/timeVaryingUniformFixedValue/
$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived/timeVaryingUniformTotalPressure/
The gravity vector can be overridden with a vector from your
interpolationTable<vector> in whichever solver you need to use. If
the interpoltationTable<vector> you construct is called myInTable, the
cose would look something like:
g.value() = myIntTable(runTime.value());
Unfortunately, i don't know how to implement these ideas to the code.
What do you think about it? Do you have any suggestion?
Regards
Stefano
Old   February 8, 2010, 12:04
Alberto Passalacqua
Hi guys,
Thousands of values as a function of time, or does your "gravity vector" change as a function of the position too?
Best,
Alberto
Alberto Passalacqua
Old   February 8, 2010, 12:22
Stefano
Thousands of values as a function of time. It is uniform in space (i mean constant in position).
Imagine the small example that i wrote before but multiplied by thounsands values.
flowtime gx gy gz
0.1 0.1 0.1 1
0.15 0.2 0.1 1.5
0.2 0.8 -0.5 1.5
.........(thousands rows)....
Stefano
Old   February 8, 2010, 12:46
Alberto Passalacqua
I agree with the suggestion of using an interpolationTable. You can take a look at this:
http://foam.sourceforge.net/doc/Doxy....html#_details
and use the constructor from the name of the file containing the data table, for example, or, if you prefer, you can set the file name containing the data in a specified dictionary and construct using that dictionary (as done in timeVaryingUniformFixedValue).
What problems did you meet when trying to implement this?
Best,
Alberto Passalacqua
Old   February 9, 2010, 04:40
Stefano
My only problem is that i'm not so expert yet to change the code. I'm still studying it, but it's still quite complicate for me.
Moreover the interpolation file is used (i think) only to interpolate between two values: but how does the code read the file, select the right value for each flowtime and change the value in its calculation?
Regards
Stefano
gravity, time, variation
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Simulation of sloshing by time varying gravity Manoj Kumar FLUENT 3 June 13, 2011 03:34
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
variation of gravity with time rajani FLUENT 0 February 16, 2005 02:45
