accessing multiple user-defined libraries from one .so file
Like Tree1Likes
  • 1 Post By akidess
Old   March 3, 2011, 19:52
Default accessing multiple user-defined libraries from one .so file
elbert
elbertj is on a distinguished road
I have created a few user-defined libraries into "libmy.so" and would like to use them one at a time in application simpleFoam. Hence I refer to only "libmy.so" in the controlDict. What I notice is that only the latest built library is accessible.
Can I store more than one user library in a single .so file?
Thanks,
Elbert
elbertj is offline   Reply With Quote
Old   March 4, 2011, 04:09
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
To me it sounds like this: You have multiple folders with the Make/files specifying the same output file. Now naturally every time you run wmake libso, the linker will overwrite the last binary - it's what you told it to do. If you want to link all files into one library, you will have to write one Make/files for all of them, doing something like the following:
lib1/source1.C
lib1/source2.C
lib2/source2.C
LIB = $(FOAM_USER_LIBBIN)/mylib
jobin2600 likes this.
akidess is offline   Reply With Quote
Old   March 4, 2011, 12:37
elbert
Thanks Anton! I am now able to store multiple user-defined libraries in one .so file and use them.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 00:20
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
