AachenBomb
Like Tree3Likes
  • 3 Post By henrik
Old   June 27, 2005, 07:42
Default Hi there, I'd like to simul
Jean Kübbeler
jean_kuebbeler is on a distinguished road
Hi there,
I'd like to simulate diesel spray and ignition for
my diploma thesis beeing part of a cold start project.
Where can I get information, like recent thesis, on creating a model in Open Foam.
Is Aachen Bomb the right solver. And what are the differences to the KIVA solver.
Thank you.
Sincerely,
Jean
jean_kuebbeler is offline   Reply With Quote
Old   June 27, 2005, 10:32
Default Hey, The aachenBomb case us
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Hey,
The aachenBomb case use the dieselFoam application, you have mixed up your terminology there slightly.
Since I started with KIVA and was part of developing the dieselFoam application I know what the important differences are
1. KIVA solves for internal energy, dieselFOAM - enthalpy.
2. The spray models in KIVA are all available in the dieselSpray class (although turbulent dispersion is handled slightly different)
3. The chemistry/combustion in KIVA is a bit tediuous to use and the standard chemistry solver is not very good for larger mechanisms. The chemistry in dieselFoam is based on the CHEMKIN approach and use a correct stiff ODE solver. The chemistryModel in OpenFOAM has the option to solve chemistry as KIVA does (sequential), but I do not recommend anyone using it, since it was implemented just for direct comparison between KIVA/OpenFOAM. Further, the combustion model in dieselFoam is hard-coded and is based on Chalmers Partially Stirred Reactor model.
You should be able to run any KIVA case (not using valves) in OpenFOAM using the kivaToFoam converter.
N
niklas is offline   Reply With Quote
Old   June 28, 2005, 05:00
Default Thanks for the fast answer. I
Jean Kübbeler
I am now looking for good literature (for beginners) about the dieselFOAM application.
See you,
Jean
Old   April 14, 2009, 05:51
Michael
farbfilm is on a distinguished road
does anybody have some literature or documentation for the dieselFoam solver??
For my thesis, I have to know the basics how the Euler/Lagrangian approach is realized in OpenFoam!!
What I already know is the basic idea of this approach - the gasphase is treated like a continuous fluid (Euler approach) and for the disperse phase the equation of motion is solved!
But there are some things, that are unclear to me:
(1) What forces are considered in the equation of motion for the droplets?
(2) What kind of basic equations for the continuous phase are solved?
(3) How are the two phases coupled? Is there just an influence of the continuous phase on the disperse phase or vice-versa or both??
(4) What equation are solved first - the continuous or disperse phase??
(5) The equations for droplets are solved every timestep?? ( I read, that it is common to solve the equations for the disperse phase just every 5...10th timestep)
(6) Does turbulence influences the motion of the doplets??
It would be great if someone could help me??
Thanks, Michael
farbfilm is offline   Reply With Quote
Old   July 22, 2009, 23:24
Smile
HuangWei
huoyinghw is on a distinguished road
Originally Posted by farbfilm View Post
Thanks, Michael
Hi alls,
i also want to know the answers that Michael has asked.
Does anyone have any idea?
Thank you, huoyinghw
huoyinghw is offline   Reply With Quote
Old   July 23, 2009, 03:46
Henrik Rusche
henrik is on a distinguished road
Dear KIVA-converts,
you can download Niklas's thesis here:
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/NiklasNordinPhD.pdf
There is also "fresh" material that came out of the PhD course at Chalmers:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008
and Berhard's contribution: icoLagrangian
http://openfoamwiki.net/index.php/Co...LagrangianFoam
please consult the associated threads on this forum when running into trouble.
Guess this will keep you busy for a while
Henrik
ramakant, Prasque and amolrajan like this.
henrik is offline   Reply With Quote
Old   November 9, 2010, 18:18
anfho is on a distinguished road
Dear All,
I also would like to run the aachenBomb, but on OF1.5. However, in the tutorial folders, the input files for that turorial are missing...
I downloaded OF1.7.1 and all of the required aachenBomb input files are there. Is it possible to use these input files and run it on OF1.5?
Thanks! Andreas
anfho is offline   Reply With Quote
Old   November 10, 2010, 14:51
Nope, it is not working. But here is the link where to download the old tutorials:
http://sourceforge.net/projects/foam/files/
Regards, Andreas
Old   May 3, 2012, 02:23
Wang
enjoybitter is on a distinguished road
I am new to OpenFOAM.
Could you please tell me what is AACHENG BOMB?
Is there any reference?
enjoybitter is offline   Reply With Quote
FoamX error aachenBomb case Ervin Adorean (Adorean) OpenFOAM Pre-Processing 13 March 7, 2005 03:50
