Simulate an ignition point in dieselEngineFoam ?
Old   July 30, 2012, 10:14
Default Simulate an ignition point in dieselEngineFoam ?
Gregory Paladin
paladin is on a distinguished road
Hi Foamers !
I'm using OF1.7.1 (because engineFoam/sprayEngineFoam from 2+ are not working properly http://www.cfd-online.com/Forums/ope...tml#post371908 ) and I'd like to use a solver that solve chemistry for engine cases... wich is dieselEngineFoam.
Problem is, i'm trying to simulate a spark ignition engine, so i need an ignition point, like in engineFoam, but dieselEngineFoam doesn't use it (because diesel engines have a compression ignition, not a spark ignition...)
Is there any way around that? Or any other solver that might do the job?
Could setField for Temperature of 2000+ K in a box the size of a spark plug work?
I would prefer a cleaner solution, but if I don't have a choice...
Thanks all,
Gregory
paladin is offline   Reply With Quote
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:07
CFX Post: Problems with moving point cloud for changing time steps spatialtime CFX 0 December 7, 2009 04:56
Use smoke density to simulate water Wei-zhi Liao Main CFD Forum 0 February 13, 2006 03:06
Shell Ignition Model Felix Main CFD Forum 0 February 10, 2006 00:40
Ignition modeling Julie Polyakh Siemens 0 May 20, 2004 08:05
