buoyantPimpleFoam - pressure field
Like Tree1Likes
  • 1 Post By Fabf
Old   February 16, 2015, 05:53
Default buoyantPimpleFoam - pressure field
F.F.
Fabf is on a distinguished road
Dear Foamers,
simulation case: thermal water storage which is loaded with hot fluid. Imagine a cylindrical tank with horizontal radial inlet/outlet discs near top resp. bottom.
Problem is the pressure field distribution. According to p = p_rgh + rho*gh pressure decreases correctly with height (nice explanation here. But at the bottom p equals 1e5 Pa so that there is negative pressure at the top. Since all pressure gradients are okay and density is just a function of temperature, there are no converging issues and the results are reasonable. But still, where does it come from?
My p_rgh-file:
internalField   uniform 1e5;
boundaryField
  "(SYMM_F|SYMM_B)"
      type wedge;
    "(OUTLET)"
        type            prghPressure;
        rhoName         rho;
        p                uniform 1e5;
    "(INLET)"
        type            zeroGradient;
      "(WALL_DIFF|WALL_DIFF_MASTER|WALL_DIFF_SLAVE|WALL_SIDE|WALL_TOP)"
        type            fixedFluxPressure;
        value           $internalField;
p-file:
boundaryField
  "(SYMM_F|SYMM_B)"
      type wedge;
    "(OUTLET|INLET|WALL_TOP|WALL_DIFF|WALL_DIFF_MASTER|WALL_SIDE|WALL_DIFF_SLAVE)"
        type            calculated;
I tried the following:
- change all values of p and p_rgh = 1e5 to rho*g*h with h - height of tank--> gives a pressure field close to reality (pressure at top is around 1e5Pa), but I am not really happy with that solution..
- apply a fixed pressure p_rgh=1e5 to the top wall (lid), keep U=(0 0 0) --> outflow through wall, although wall has fixed value to zero for U
- initialize with correct pressure field using funkySetFields (according to here--> same field after some timesteps
- trying different BCs.. --> same
- try setting presure reference point --> only yields for closed systems
What I am missing? From a physical point of view: internal field of p_rgh has to be around atmospheric pressure, since the hydrostatic component is applied afterwards. Also my outlet pressure has to be p_rgh=1e5Pa ..?!
my other files:
-thermophysicalProperties
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
dtdp = off;
    specie
        nMoles          1;
        molWeight       18;
    equationOfState
          rhoCoeffs<8>  (-540.4680832401600000 16.7586613589465000 -0.0668647676334458 0.0001178920951103 -0.0000000809669445 0 0 0 );
    thermodynamics //f(T)
        Hf              0;
        Sf              0;
        CpCoeffs<8>     (4193.0 0 0 0 0 0 0 0);
        muCoeffs<8>
           ( 0.260216875208536 -0.0029069831827857 0.0000122820941795 -0.0000000231946446 0.0000000000164938 0 0 0); //
         kappaCoeffs<8>
            ( 0.596 0 0 0 0 0 0 0);
fvSolution:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "rho.*"
        solver          GAMG;//PCG;
        //preconditioner  DIC;
        tolerance       1e-6;//0;
        relTol          0;
    p_rgh
        solver          GAMG;//PCG;
        tolerance       1e-6;//1e-8;
        relTol          0.01;
         smoother    GaussSeidel;
    cacheAgglomeration true;
    nCellsInCoarsestLevel 10;
    agglomerator faceAreaPair;
    mergeLevels     1;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "(U|h|e|k|R|omega)"//"(U|h|e|k|epsilon|R)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-8; // 6; http://www.dicat.unige.it/guerrero/of2014b/12tipsandtricks.pdf
        relTol          0.0;//.1
    "(U|h|e|k|R|omega)Final"//"(U|h|e|k|epsilon|R)Final"
        $U;
        relTol          0;
        omega
        solver           smoothSolver;
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 50;//1
    nCorrectors     2;//2
    nNonOrthogonalCorrectors 2;//20;//0;
    //pRefPoint (5,39 1.79 0);
    //pRefValue 1e5;;
    residualControl
        p_rgh
            tolerance 1e-03;
            relTol 0;
            absTol 0;
relaxationFactors
    fields
        p               0.3; //0.3
	"p_rhg*"		0.3;//0.3
	rho		0.7;
    equations
        "U*"               0.7; //0.7
        "T*"               0.7; //0.7
        "(h|e)"		0.7; //0.7
        k               0.7; //0.7
        omega           0.7; //0.7
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,h)      Gauss upwind;
    div(phi,e)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    //div(phi,epsilon) Gauss upwind;	k-E Modell
    div(phi,omega)  bounded Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(phi,K)      Gauss linear;
    div(phi,Ekp)    Gauss linear;
    div(R)          Gauss linear;
    //(div((muEff*dev2(T(grad(U))))) Gauss linear;  k-E Modell
    div(phiv,p) Gauss upwind p;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
Thanks in advance!
Fabf is offline   Reply With Quote
Old   February 16, 2015, 17:51
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
For most of the incompressible formulations in OpenFOAM you'll always see the pressure term inside of a gradient operator in all of the transport and intermediate solution equations. What this means is that the absolute value of pressure could really be anything as you're always solving for grad(p), not p.
The pressure reference point you mentioned would be required for cases where you don't have a dirchlet BC set for pressure, and thus pinning it to some unique solution.
In your case having a negative pressure doesn't really mean anything, you can likely arbitrarily change the outlet pressure value to what ever you like and still get the same flow field.
I hope that helps!
Kyle
kmooney is offline   Reply With Quote
Old   February 17, 2015, 04:02
F.F.
Perfect. So there is nothing I have to worry about.
I will just change the outlet pressure to p_atmo+rho*g*h_total to adjust the entire field and then everything looks nice.
Thanks!
alijamal likes this.
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
custom pressure field at the faces Souviktor FLUENT 0 April 3, 2009 08:09
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
