November 13, 2012, 04:13 |
Calculation of k and epsilon freezes
I've got a problem with my calculation von k and epsilon. I'm trying to simulate a rotating geometry with a modified version of interFoam. The geometry is rotating in different directions and my fluid is sloshing, but the values for k and epsilon just dont chance anymore after some iterations. At the beginning there are some Iterations for k and epsilon Code:
MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -2.49977e-20 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -7.02031e-21 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -1.31893e-20 Max(alpha1) = 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -4.39865e-20 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.00109002, Final residual = 8.85396e-08, No Iterations 124 time step continuity errors : sum local = 1.83749e-09, global = 2.10194e-11, cumulative = -6.24155e-11 DICPCG: Solving for p_rgh, Initial residual = 0.000154468, Final residual = 9.29858e-08, No Iterations 114 time step continuity errors : sum local = 1.93264e-09, global = -1.87438e-10, cumulative = -2.49854e-10 DICPCG: Solving for p_rgh, Initial residual = 2.61918e-05, Final residual = 9.23886e-08, No Iterations 79 time step continuity errors : sum local = 1.9189e-09, global = 2.37918e-10, cumulative = -1.19357e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.000340262, Final residual = 6.24431e-09, No Iterations 2 bounding epsilon, min: -4.02028e-08 max: 0.107857 average: 5.80718e-05 DILUPBiCG: Solving for k, Initial residual = 0.000539149, Final residual = 1.33527e-11, No Iterations 4 bounding k, min: -7.24082e-12 max: 0.00100971 average: 1.00796e-05 ExecutionTime = 17.68 s ClockTime = 18 s Code:
MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -2.15831e-20 Max(alpha1) = 1.00001 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -2.96242e-20 Max(alpha1) = 1.00001 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -1.20443e-20 Max(alpha1) = 1.00001 MULES: Solving for alpha1 Liquid phase volume fraction = 0.979575 Min(alpha1) = -9.61596e-21 Max(alpha1) = 1.00001 DICPCG: Solving for p_rgh, Initial residual = 0.000269819, Final residual = 9.59801e-08, No Iterations 26 time step continuity errors : sum local = 1.39057e-09, global = 1.24122e-10, cumulative = -4.05415e-08 DICPCG: Solving for p_rgh, Initial residual = 1.5512e-05, Final residual = 9.55703e-08, No Iterations 21 time step continuity errors : sum local = 1.3846e-09, global = 1.14579e-10, cumulative = -4.04269e-08 DICPCG: Solving for p_rgh, Initial residual = 1.98201e-06, Final residual = 9.75346e-08, No Iterations 5 time step continuity errors : sum local = 1.41305e-09, global = 1.08762e-10, cumulative = -4.03181e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.00010125, Final residual = 7.4232e-09, No Iterations 1 bounding epsilon, min: 1.98379e-18 max: 16.2816 average: 0.00581568 DILUPBiCG: Solving for k, Initial residual = 9.96483e-11, Final residual = 9.96483e-11, No Iterations 0 ExecutionTime = 936.41 s ClockTime = 977 s I tried several things I found on the internet including:
Here are my current BCs for k, epsilon and nut k Code:
boundaryField { outlet { type inletOutlet; inletValue uniform 0.001; value uniform 0.01; } symmetry { type symmetryPlane; } wall { type kqRWallFunction; value uniform 1e-06; } Code:
boundaryField { outlet { type inletOutlet; inletValue uniform 0.0001; value uniform 0; } symmetry { type symmetryPlane; } wall { type epsilonWallFunction; value uniform 0.001; } Code:
boundaryField { outlet { type calculated; value uniform 0; } symmetry { type symmetryPlane; } wall { type nutkWallFunction; value uniform 0; } causing the problem. If anyone has an idea what I could do, please let me know. My englisch isnt the best so if you dont understand something just ask me Greets Nigirim |
November 14, 2012, 07:52 |
I got a similar problem!
here: http://www.cfd-online.com/Forums/ope...alcontrol.html Let me know when you have a solution... Thanks! |
calculation of k, epsilon and omega | kroetenechse | OpenFOAM Pre-Processing | 31 | March 5, 2021 10:32 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
wall functions.-E value, epsilon calculation | Xabi | OpenFOAM Running, Solving & CFD | 3 | February 25, 2014 11:24 |
epsilon and K blowing up. | sivakumar | OpenFOAM Running, Solving & CFD | 1 | October 25, 2012 04:50 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
