RAS simulations of flow around wall mounted cube
Old   February 13, 2013, 09:55
Default RAS simulations of flow around wall mounted cube
nore5 is on a distinguished road
Greetings to all,
I am currently trying to set up an OpenFoam model for 3D flow around wall mounted cube.
Here are some details on the model
*Meshing- SnappyHexMesh so to get refinement qround the cube and have a mesh distribution similar to the one enclosed.
*Solver - PisoFoam with k-epsilon for turbulence modelling.
*Boundary conditions /chosen according to a reference paper/
**cube wall functions
**channel upper wall symmetryPlane
** channel later sides symmetryPlane
**channel bottom wall wallFunction
** velocity inlet- set uniform 5m/s for the moment but will use GroovyBC later> I just want to see what will happen.
** outlet inletOutlet boundary condition.
*System , I had copied and adapted the fvSolution, fvSchemes and controlDirect of a k-omega model for the same case.
*Turbulence parameters calculation using guidelines in user guide.
Once I run simulations, it directly crashes after three time steps with unrealistic and unexpected bounding values for the courant number, k and epsilon.
I saw that there were some fixes to do for the mesh too. But my biggest concern is those strange values I get when running the cases. Please, note that OpenFoam is a completely new to me and I am in the process of learning.
Please could you have a look at the model and tell me how I can improve it to avoid the errors I get? Enclosed is the zip file.
Notice that to run the case, the snappyHexmesh process takes some time. Sorry, I could not send the zipped folder with the files resulting from SnappyHexMesh because of size limitations. I can send it by mail upon request if needed to gain time.
Thank you in advance for your help and guidance.
Nore
nore5 is offline   Reply With Quote
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
FLUENT LES Simulation of flow past a cube NGH FLUENT 6 November 13, 2012 23:45
Setting Inlet as Wall until flow occurs via UDF emmkell Fluent UDF and Scheme Programming 0 May 1, 2012 12:05
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 13:31
