is internalField(U) equivalent to zeroGradient?
Old   March 6, 2013, 17:09
Default is internalField(U) equivalent to zeroGradient?
immortality's Avatar
Ehsan
immortality is on a distinguished road
when I set BC for U to zeroGradient or:
right
     type groovyBC;
     fractionExpression "0";
     gradientExpression "vector(0,0,0)";
it answers without any error
but when I set it to:
right
     type groovyBC;
     fractionExpression "1";
     valueExpression "internalField(U)";//vector(internalField(U).x,0,0)
it falls to an error on T(energy equation probably) as so:
From function janafThermo<EquationOfState>::limit(const scalar T) const
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -3333091.721
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 4080511.561
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -7124696.499
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 5774453.414
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -6575768.989
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 5981361.409
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 1404258.482
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -17090209.16
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 36020792.5
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -94818398.64
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 40233402.34
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -106376680.8
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 37389446.51
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -76115211.3
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -24650104.63
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -26951665.22
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 471535.4463
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 465677.0027
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 277204.4414
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -145721.0621
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 15779.92442
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 112883.4828
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -3083.273126
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 43.52495911
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 4976486.257
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 3178348.937
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -32897237.32
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -44825686.95
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -22612.51171
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -1870.615087
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 9690.272357
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -39521.73991
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 93265.31041
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -340838.0148
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 610015.5259
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -1813983.217
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = 2650248.864
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000;  T = -6558287.943
I thought that internalField(U) or vector(internalField(U).x,0,0) do the same way as zeroGradient(or in groovyBC gradientExpression"0" does).
why?
immortality is offline   Reply With Quote
Old   March 6, 2013, 17:15
Ehsan
is it possible to have the help of Mr.Gschaider if he doesn't have sulked?
Old   March 7, 2013, 06:09
Ehsan
why they don't act the same way?
Old   March 8, 2013, 03:47
Ehsan
does anyone have any experience or knowledge about this issue?
Old   March 8, 2013, 09:30
Ehsan
dear Bernard whats your advice about it?
Its important to know your opinion because of your expertise on groovyBC.
Thank you for your and others comments.
Old   March 10, 2013, 05:36
Ehsan
the question persists if anyone has an idea it will be thanked.
Old   March 15, 2013, 04:22
Ehsan
is the question so much hard?
I only want to know the cause.why internalField and zeroGradient act differently in test although they seem should be the same?
Old   March 29, 2013, 01:27
Ehsan
no any answer?
second order schemes marine OpenFOAM 67 April 11, 2022 18:19
interFoam andrea.pasquali OpenFOAM 8 February 23, 2021 12:06
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle Quatschinsky OpenFOAM Running, Solving & CFD 7 March 27, 2014 05:08
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
