May 14, 2014, 04:40 |
coupled solver in OpenFOAM
何刚
Is there any solver in OpenFOAM which solves all the equation ( continuity, momentum, energy, turbulence equation) at the same time? If so, we can calculate the compressible turbulent combustion flows. And how can we modify a slover or case in order to do this?
May 14, 2014, 06:16 |
Werner
Rep Power: 12 |
You can take the coalChemistryFoam, it calculates continuity, momentum, energy, turbulence, and combustion. There is also a tutoial case "CoalChemistryFoam" in the lagrance case, which is maby the case you need. Skip the lagrange clouds, modify the mesh and i think you have what you need!
May 14, 2014, 06:38 |
#3 | |
何刚
Where can I find coalChemistryFoam ? Is it in the OF-2.3.0? |
May 14, 2014, 07:06 |
Werner
Rep Power: 12 |
i know its availible in OF2.2.0 so i think it is also in OF2.3 take a look in the tutorial at lagrange.
May 14, 2014, 07:49 |
何刚
compressible, coupled solver |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon | qinmaple | OpenFOAM Announcements from Other Sources | 4 | August 10, 2012 11:00 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
The seperated solver and coupled one | summer | FLUENT | 0 | July 5, 2006 15:06 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 08:30 |
