Why is icoFsiFoam considered deprecated?
Old   May 28, 2014, 10:59
Default Why is icoFsiFoam considered deprecated?
Nikolac is on a distinguished road
Hello everyone,
I'm working on a biophysically motivated FSI problem and I wonder why the icoFsiFoam solver is deposited in a "deprecatedSolvers" folder. What should be used instead? I'm not talking of course about the particular fluid/solid models, but whether there is now a method/algorithm available that is considered better for some reason?
Cheers,
N
Nikolac is offline   Reply With Quote
Old   February 26, 2015, 08:18
Svensen is on a distinguished road
The same question... Maybe you already know the answer ?
Svensen is offline   Reply With Quote
Old   March 5, 2015, 10:00
Damon Lee
D_LEE is on a distinguished road
I think that it is considered depreciated because of icoFsiElastciNonLinSolidFoam. From looking at the code it seems that icoFsiFoam doesn't do any loop between solid and liquid within a time step, which might be why they said 'Set up as a fake fluid structure interaction solver' it does:
#       include "setPressure.H"
#       include "solveSolid.H"
#       include "setMotion.H"
#       include "solveFluid.H"
While in the same spot icoFsiElastciNonLinSolidFoam does:
do
            outerCorr++;
#           include "setInterfaceDisplacement.H"
#           include "moveFluidMesh.H"
#           include "setInterfaceForce.H"
#           include "calcFsiResidual.H"
        while
            (fsiResidualNorm > outerCorrTolerance)
         && (outerCorr < nOuterCorr)
Also icoFsiElastciNonLinSolidFoam can supposedly run in parallel, but getting that to work in parallel for me with proper Hron Tureck values makes it crash. I get the same error as the people in this thread: http://www.cfd-online.com/Forums/ope...tml#post504083 and it appears that there is no working solution, even though there is an AllrunPar script there.
I think that if you want a steady-state solution and only use one core you may aswell use icoFsiFoam.
Svensen from the other post I think that you can view it in paraview if for do paraFoam -case fluid.
D_LEE is offline   Reply With Quote
Old   March 24, 2021, 04:57
Wassim Abdel Nour
wa$$im is on a distinguished road
Could it also be because the solver has stability issues ?
wa$$im is offline   Reply With Quote
[PyFoam] running pyFoam(Plot)Runner.py in parallel Studi OpenFOAM Community Contributions 10 September 6, 2015 16:38
Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam) Eferal OpenFOAM 3 October 3, 2013 03:04
icoFsiFoam in OF1.6-ext does not work mechy OpenFOAM 4 July 26, 2011 03:14
IcofsiFoam not supported under released 141 package pi06jl6 OpenFOAM Running, Solving & CFD 4 June 26, 2008 13:59
Errors in running a icoFsiFoam case jin_xu OpenFOAM Pre-Processing 0 June 9, 2008 06:48
