August 7, 2014, 15:02 |
nut and nuTilda in simpleFoam
Michael Kruger
Rep Power: 11 |
What are the differences between nut and nuTilda in the simpleFoam solver?
In the PitzDaily simpleFoam tutorial, both nut and nuTilda are set to zero, does this mean the problem is modelled as inviscid? In the airFoil2D tutorial both nut and nuTilda are given values of 0.14 m^2/s. I believe the kinematic viscosity of air at room temp is about 15.11e-6 m^2/s, where in the world does the value of 0.14 m^2/s come from?? Is it perhaps because of a scaling factor introduced somewhere? Any clarification on the subject will be greatly appreciated. Thank you in advance. |
August 8, 2014, 03:33 |
Philipp
Rep Power: 26 |
Hi Michael,
The files you are refering to provide boundary and initial values for the turbulent viscosity. (That's why it is "nut" and not just "nu"). Depending on the turbulence model you use they have different names. I don't know the airFoil2D tutorial, so I don't know which turbulence model it uses and thus which of the files is actualy needed. The fastes way is just to delete both files and start the solver. It will tell you the name of the files that are needed to run. "Nutilda" comes from the Spalart-Allmaras model, where "nut" is transformed to "nuTilda" and the model equation is solved for nuTilda. Anyway, if you set the value to zero in these files it just means that the initial value is zero. If you don't get convergence you can try other values, such as "0.14m^2/s" in the tutorial. The viscosity of air is set in a different file (constant/transportProperties) and should match the value you wrote. Philipp.
The skeleton ran out of shampoo in the shower. |
August 8, 2014, 03:38 |
Michael Kruger
Rep Power: 11 |
Excellent thank you Phillipp, that solves my problem.
Might you be able to help be with this question: http://www.cfd-online.com/Forums/ope...-anywhere.html? Thank you in advance.
------------------------------------------------------- Michael |
nut nutilda, simplefoam, solvers |
nut and nuTilda | phile | OpenFOAM Running, Solving & CFD | 32 | June 13, 2020 08:53 |
nut and nuTilda in simpleFoam | mich_K | OpenFOAM Running, Solving & CFD | 0 | August 7, 2014 13:42 |
how to set nut and nuTilda? | aynjust | OpenFOAM Pre-Processing | 1 | July 7, 2013 05:36 |
incorrect to use nuTilda wall functions for k-epsilon? | newToOpenFoam | OpenFOAM Pre-Processing | 0 | December 14, 2011 05:15 |
nut values | asharma | OpenFOAM | 20 | February 17, 2011 12:35 |
