Changing writeInterval on the fly doesn work in parallel runs
Old   August 10, 2014, 16:48
Default Changing writeInterval on the fly doesn work in parallel runs
anonymous
ssss is on a distinguished road
I'm using OF210 and I implemented an automatic change the writeInterval depending on the time of the simulation. Here is the implementation in the solver :
int main(){
IOdictionary controlDict(IOobject("controlDict", runTime.system(),mesh,IOobject::MUST_READ,IOobject ::AUTO_WRITE));
while (runTime.loop()){
    if(runTime.value()>=0.05){
        Info<<"I enter"<<endl;
        controlDict.set("writeInterval",0.05);
        controlDict.Foam::regIOobject::write();
It works as I expect during serial runs, the controlDict changes and the changes are notified right to the solver.
But once I make a parallel run, the controlDict which is in every /case/processor*/system/ changes, but the one in the case/system/ doesn't change, and I don't know why, but he uses the writeInterval which is in the main case folder.
Here is my controlDict:
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         700;
deltaT          0.0005;
writeControl    adjustableRunTime;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
maxCo           0.7;
adjustTimeStep yes; // Or no
maxDeltaT 1;
Anyone has an idea on how to fix this?
Thank you very much.
ssss is offline   Reply With Quote
Old   March 16, 2016, 05:06
Brugiere Olivier
brugiere_olivier is on a distinguished road
Hello everyone,
I have the same problem with version OF240. Does someone has an idea to fixe the problem?
thank you in advance
brugiere_olivier is offline   Reply With Quote
Old   September 25, 2017, 14:22
dupeng is on a distinguished road
Hi, Have you solve this problem? I have this problem too recently and don't have a solution. Thanks.
dupeng is offline   Reply With Quote
Old   September 26, 2017, 00:43
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
It may be that that doesn't work. In parallel, the calculating task has to be splitted into tasks for each processor. Changing the control dict would lead to a compilation of the result so far an a new splitting. I don't think that this is implemented.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   September 26, 2017, 03:01
Thanks. I found another soluting using the timeactivatedfileupdate function object to copy and replace the controlDict reaching a specified time. It works great for serial simulations. But for parallel simulations, it only regIOobject for the first time. The controlDict is replaced after that but the changes are not updated. Very strange. I am using OpenFoam 3.0.
RBF motion solver does not work well in parallel lakeat OpenFOAM Bugs 3 August 8, 2013 05:50
Could SU2_V2.0.2 work properly with continuous_adjoint.py script in parallel mode? Tommy Chen SU2 Shape Design 1 April 18, 2013 13:06
LTSReactingParcelFoam doesn't work in parallel Chrisi1984 OpenFOAM Running, Solving & CFD 4 August 6, 2012 03:08
OpenFOAM 2.0.0. and 2.0.1 doesn't work in parallel mode rv82 OpenFOAM Running, Solving & CFD 3 October 3, 2011 10:47
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
