November 15, 2014, 12:47 |
Foam Fatal error running icoFsiFoam
ricardo avila
Hi everyone,
I am having trouble running icoFsiFoam. I get the following error shown while running it in the fluid directory: --> FOAM FATAL ERROR: Cannot find file "points" in directory "constant/solid/polyMesh" From function Time::findInstance(const fileName&, const word&, const IOobject::readOption) in file db/Time/findInstance.C at line 148. FOAM exiting I have ran blockMesh in both, the solid and the fluid directory. Also ran checkMesh on both resulting in "mesh ok". I have also checked that the points file is in the solid directory as well as in the fluid... I have not been able to find related information, im kind of lost here... any ideas? Thanks a lot in advance for your reply, Ricardo |
November 17, 2014, 13:12 |
Hao Chen
Did you run make links? Best regards Hao |
January 18, 2018, 12:05 |
Sam
Rep Power: 8 |
Had the same problem. please has anyone been able to solve the problem? All my links are in place.
Thanks Samuel |
March 28, 2019, 13:47 |
xena
Rep Power: 7 |
hi sam
if you could solve the problem, please tell me what you did, because I'm facing the same issue even though I did all the steps |
icofsifoam, openfoam, solvers |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
